please help, i have a jetting problem that has me clueless, my motor has k&t drag ported cylinders--4mm long rod crank--152 pounds of compression--vforce 2's--reed spacers--shearer in frame pipes--+4 advance timing--cool head--34mm pj carbs--air box with no lid and a k&n filter, i am running 45 pilot and 155 mains, i want to get the jetting close before i burn up my new engine, on the first start it started right up and was pretty good until i took the chokes off then it bogged, i put the chokes back on and it was pretty good again, putting the chokes on and it running better tells me that it is to lean, i pulled the plugs and they are wet with gas so that tells me it is to rich and needs smaller pilot jets, i am clueless, i looked through the jetting section and found 1 user with pretty much the same setup and that is the jets i used, also now the quad won't even start unless i put new plugs in because of them being wet, if it is lean how many jets should i go up, and if it is rich how many jets should i go down,,,,,,,,,,,,,,thanks in advance
