Kingsley78
Kingsley78's Achievements
  1. Kinda looks like the plugs wernt hot enough but you would see that in both domes. Maybe one carby was out in its jetting. The left one looks sooty, like its rich but im no pro...
  2. I sent dlnos a pm. I guess il have to make a note to him that il require it to run using the USA 93 octain?
  3. Port timing? Have you shifted your bores up with a thicker base gasket to give TDC piston clearance?
  4. Im still virginal around this site. Are you able to drop some of the site builders names or how to get in contact with Redline, preferably an email or website?
  5. Im in the need of custom domes for my 4mm stroker with a cool head. Im running blaster piston so i need something to suit. I will be able to give piston height above deck and port heights to determin the compression ratio, so i gain the maximum use from 98 octain fuel. Can anyone help or recomend some help. I have Paypal Kingsley
  6. Sounds like the water pump seal
  7. Im not a pro but it sounds like your motor was built to run high octane and by using 87 octane, you made it detonate from the first bang. Im guessing it was detonatin so bad that the fuel was becoming unstable long before TDC and pre-ignighting the fuel, meaning when it was time for the spark to normally ignight it, you had no fuel or very little left to burn. You would have slowly been chipping away at your pistons, causing them to leak and lower your compression and crank case pressure, also causing power to drop fast.
  8. Ive made a gastket to suit my 4mm so that my pistons dont go beyond the deck. If i lower the bores with a thinner/standard gasket and run custom domes, how will that effect my port timing?
  9. Can anyone help with an idea of my porting. Ive only messured the exhauste and the top of the port to the deck is 28mm and the bottom of the port to deck is 55mm. Ive got a feeling they are high as im not seeing a very high compression ratio. Cheers
  10. Im running a 66.5mm bore and 58mm stroke (4mm stroker) . Where have you taken the figures from? Im guessing i delete the cc space that the head of the spark plug would take up or isnt this a concern?
  11. Yeah it makes sence and it sound like im understanding it all as i go. Id like to get away from the use of race fuel as its over $2 a ltr over here in Aus. Im going to deal with some machinist and experiment at increasing the domes CC's in the chambers once i get them until i reach a ratio that will be safe on 98octane. My ports must be fairly high then plus the balster pistons to return a 100psi reading. I have to measure them when i CC the engine and will compare then to stock.
  12. Thats right but it does change the ratio.... How do i work out the cc of the piston with the dome above the deck? Do i messure the cc from the shoulder of the piston to the deck, then add the squish thickness and minus the piston dome cc from the head dome?
  13. I bought a jet ski for that..... Not a good ides to put your shee through water anyway, makes the seat slippery.
  14. dajogejr- You are probley very correct with your susgestions. Im yet to know what my ratio will be until i recieve the domes and cc it all. I may still increase the dome size if fuel is going to be too much of an issue. Im not looking forward to the extra maintenance that comes with methanol so that could be the deciding factor for me. Im running trued and welded 4mm Hotrods crank, Some kind of porting (came with the bike), blaster forged 66.5mm pistons, cool head but with banshee 22cc domes. I went looking to see why i wasnt getting power that i expected and learnt that my domes wernt suited and were only giving 100psi and the full build. I think i was given some wrong advice and ordered the 17cc domes to suit blaster pistons. Im just trying to cover all options to make this package work for me. At this stage i think i may be increasing the domes size to work with 98 octane pump fuel.
