jacquesraney
Everything posted by jacquesraney
  1. do i need to fill the coolant resevoir under the seat?? is it for back up???
  2. thanks... well give it a shot... i hope thats all.. it cant be much... i guess thats what happens when you let em sit and not ride....
  3. thanks... well give it a shot... i hope thats all.. it cant be much... i guess thats what happens when you let em sit and not ride....
  4. So my buddy has an 05 .. with Toomey T5's.. cool heads. probably has 10 hours on it... never rides it.. bought new...Well this year he decided to bring it out but is running into a few problems.. Drained all the fuel ..took apart the carbs.. new plugs.. it takes like 20 kicks... then its real sluggish ...then it will run really good and fast..then bog down really low...and this goes on and on... fowling plugs also.. he seems to think it is a float bowl issue because it is leaking a signifigant amount of gas frome the carb tube on the left side under the quad from the overflow tube.. please help!!!!!!
  5. Get er done
  6. How bout some Diet mountain Dew>>>//?????? EhHHH/????
  7. Buy a 'Vespa"... thier round!!!!!
  8. If it has an attatchable beer tap.. Im In!!!!
  9. time is money... to be applied correctly .. i believe items should be blasted with aluminum oxide first... then sprayed..... just my 02...(opinion)
  10. there absolutely has to be some sort of Grenade that is custom and implemented into the theme.. like a brake light cover... or something....!!!!!!
  11. I ordered the packing and the silicone,,, Ive never done this,, how hard is it??? is there a vidieo out there besides a 4- poke???... will i notice a differance??? Also.. was gonna replace my rings... ive had the Shee for 4 years .. runs strong... prolly only put 50 hrs on her.. should i do a compression check and how much for new rings and cool head gasket?????.. p.s. I run vp110 leaded...
  12. I smell a blown engine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  13. even on terrain thats not just sand,,, hard pack.. some parts of trails.. ??
  14. any one like the sand star tires?? i live in central fl and the trails get kinda loose.. anyone like sand stars???
  15. i have a stock axl.... gettin some rust .. any ideas on how to clean er up,, cheap?
  16. I heard some where that you could pour boiling water into the tank,, and hook op an air hose to the tank.. pressurize it.. and get some extra space out of it... ?????
  17. I was gonna install new rings at the end of the year.. i have prodesign cool heads.. what all do i need to order??? do i need new wristpins and circle clips... there is a video onrmatv.com.. but much diff than a shee...
  18. I wen't so fast on my banshee , I traveled back in time a WEEK !!! Did I miss anything???
  19. when i take of the cap and rev it up... it seems to move around pretty good,, can't really tell if its from vibration though,,, when I felt the actuall radiator it felt hot.. wich led me to belive that it is flowing properly.... the last flush was 20 hrs ago... thnks.. also how hard is a new impellar to install and what would you recomend???
  20. What's on your mind?
  21. pain in my ass... can i splice into the other light???????
  22. my left headlight quit working... i tested the bulb .. it's ok.. used a volt meter and i am not recieving any power,,, to the left side,, when i wired it up.. i set up for both lights to be on High Beam... can I just splice in to the right side light or will this be splitting power to 6 volts??? they are 35 watt 12 volt trail techs that are stock mount,,,, please help.....
  23. going riding soon.. me and my son... being pro- active want to carry some gear but what is the best way or thing to put in.. (tow strap, tools... phone.. etc).. Im on the shee he's on a predator 50 . ) I was thinkin back pack... any suggestions ????
  24. i use this stuff called SC-1 you should be able to get it at your local dealer... if not you can order it from rockymountain atv
