davidonmars
Everything posted by davidonmars
  1. I'm not sure who cut them I bought them off a member o the board. As far As I can tell reading the numbers done Volume is 20cc squish angle is 13 and 115 for long rod. Stock timing stock carbs 330 mains. I'll have to use another gauge tonight
  2. They were 23 mm I believe but then cut for 4mm dome has some engraving 20 13 115
  3. At 155 psi I didn't think I'd need higher octane. I'm about 1000 above sea level
  4. Can anyone tell me why my Spark plugs are Coming loose? It's a cool head with 20cc 4 mill domes running 94 octane
  5. 390 is huge what motor do you have?? I got a 4mm dune ported and I'm at 340 mains 25 pilots
  6. I can't for the life of me bleed these brakes. I just changed a caliper on the front and I tried for about 5 hours to bleed them. Pumped them and opened bleeder and sometimes fluid came out slowly and other times air. Reservoir never dropped. Hooked up a line to the bleeder then to the a bottle with fluid attached to a chain above the quad. Played around with the lever while the bleeder was Open like a YouTube video showed for a good 2 hours. This will not Build pressure for the life of me. I ha. Good solid lever squeeze before all this. Help me
  7. Leave pilot stock 25 and try 290 mains stock needle middle clip
  8. Got the crank off a member new but opened in box. Was wondering of these are supposed to be welded from factory? Couldn't see any welds on the pin. Can I tell which crank it is by the number on the rod? As far as I can tell the rod does look longer. Thanks
  9. So the green part faces inside clutch cover?
  10. Need to know what direction to put both crank seals ASAP
  11. Can't do shit Anyways who wants his number
  12. I'm pretty sure I sent as gift I'll log On see what I can do
  13. Got a coolhead and domes from him. Wrong dome size not what he said and he said it came with o rings but they weren't there. I have his number but he's not answering or returning texts
  14. Bump
  15. Anyone have pm me
  16. To the top
  17. Bump
  18. I beat craptor 700s with my Bike with just pipes. When I added my porting it was no longer a race
  19. Anyone got a set of these pipes they want to sell?
  20. Got them coming thanks
  21. Looking for 795 long rod pistons. 64.75mm would be ideal but not sure they make those of need be I'll bore to 65mm if anyone has a new set laying around they would sell. Thanks
  22. Hey guys looking for a cool head and 20cc 4mm domes if anyone has. Let me Know. Thanks
  23. Text me 4165710306 just blew a rod bearing on my stocker looking to upgrade
