cobalt
Everything posted by cobalt
I just did a rebuild an made the mistake of not tightening the front sproket nut down am it came off while riding. Luckly the chain didnt come off an far as can see no dmg done. Does anyone happen to know what size an threads that nut is or can you point me in the direction where i can find the sizes?
I just broke my chain on my shee an am wondering if anyone knows the proper chain length for a +6swing arm with stock gear in rear and 14 tooth in front. Or can show me a way to calculate the new length that I need? I am thinking of changing the gearing for dune/drag
I have a 2000 banshee with t6s,cool head with 20 domes, k&n air pods, +4 timeing and a +6 swing arm im currently running stock rear sprocket an a 14 tooth front sprocket. Im wanting to set it up as a dune/drag I broke the chain on it last summer an am wondering what the correct chain lenght should be and if there is a better gear set up I should be running and am wondering if I should be using more than a 8 paddle tire for it.
I lost my idle screw for my stock carbs with Tors removed. Was wondering if anyone knew where I could pick one up?
whoops posted in wrong forum sorry please remove.
Need some help rejetting my carbs i want to jet for riding at silver lake michigan, not sure the elevation, but ive got +2 on timing, t6 pipes, boost bottle and cool head with 20 domes not sure the current jetting set cause I am in the process of rebuilding the stock carbs when i put the new coolhead in my floats started sticking like crazy in both carbs. Any help would be much appreciated I have no clue what to do when it comes to jetting thx
Silver Lake ride and hill climb
cobalt replied to ~*Mrs. Toyboxx*~'s topic in Riding and Events Forum
Suppose to be cloudly and in the mid 60's so not to bad should be decent. I'm hoping to be up there 14th through 16th with couple shees and few bikes. Be first trip this year hope everything holds together -
thanks guys for all the info, I got some stuff to try out this weekend hopefully it works cause I aint got the cash to buy a new head just bought this one ,used but just got it.
I don't have the acorn nuts I been tryin to look around to see where I can get some havn't had any luck at the local hard ware store. when you guys put the silicone on did you put it on around where the little oring gasket is or on the outside around the threads?
I just got a Noss Performance cool head with 20 domes, I installed it and am having problems with coolant leaking from around the bolts it starts and runs fine. Just wondering if have any ideas how to fix the leaking coolant I put new o-ring set on it when i installed and I just tried putting a lil high temp gasket silicone on around the bolts and it is still wanting to leak a bit. I'm using stock nuts on it.
I'll be there on sunday the 25th provided its decent weather should have my shee and few dirtbikes. should be there around noonish so can ride when its warmest out
thanks guys for the imput There offset quite a bit so thats what kinda was worrying but yeah I did ride around with them slowly just testing them and they grabbed really well. got probably 4 inches sticking past my fenders on both sides so they are huge not sure the size exactly but they were on a yamaha warrior I know.
My stock tires are spinning to much on grass and dirt so I was looking for some more aggressive dirt tires and found some fairly new spidertracs that we had laying around. my question is do you guys think these are to aggresive for my banshee that it might damage some stuff by creating to much pull or something? My shee is fairly stock have k&n air pods, +4 on timing t5 full exhaust and tors removed. the tires are huge on there and I feel they will hurt it or break my hubs but, I wanted some 3rd party imput.
Where's the Michigan people? Raise your hand.
cobalt replied to Lifer's topic in Riding and Events Forum
Watervliet Here -
hey guys new guy here, but I hope to be there not sure if i can make it saturday tho but i know ill be there least sunday for sure should be me and couple dirtbikers
thanks guys um does anyone have any idea of a price range for the heads and domes? kinda like knowing that before getting into it just so i know what to be expecting
I have an 01 banshee with t6 exhaust, K&n pods, +4 timing, T.o.R.s removed, and a boost bottle im looking to add a cool head next cause i think thats prolly next mod i can put on without getting into boring or porting and im wondering what domes I can run on it and still be able to use pump gas I ride primarily up at silver lake and hopefully be heading to badlands soon thanks. also any recommended brands that are easy to install or have good kits
I was there Sunday and I needed a voucher if i wanted to get in before 11:30 luckly tho i was first on the waiting list so got in at 9:30 they told me the voucher system goes from hill climb to hill climb basically so this last weekend was the last weekend for the voucher system
I figured it out thanks guys I like a idiot didnt put the cross over tube back on when i installed the carbs was my first time messing with them but she seems to be running great now maybe just a lil tweeking and ill be set thanks
Hey anyone going up to silver lake this weekend for the Hill climb?
Hey I just put a Tors removal kit on my shee and now im having trouble syncing the carbs and just getting the things to run. so far the only way i can get it to start is if i put my hand over one of the carbs while i kick it for a min then release and then it will usually start next kick but the throttle is really screwy and revs way high then goes all over the place im not sure what to do ive been adjusting the cable on top of the carbs and at the thumb throttle but i cant seem to get it running any better and it still wont start without my hand over one carb any ideas would greatly help cause im at a loss
hey been reading alot about guys doing a +4 timing conversion and im just wondering what is invovled with that or how would I go about doing that myself to my shee....really new to banshees so kinda lost when I read about that any help would be great thanks
which one of those would prolly be the cheapest or best to start with and how do i check to see if the tors are removed i think they are i just have general knowledge with banshees just got mine this summer thanks
