likestoride
Everything posted by likestoride
  1. thanks for the input.did i say that the bike ran fine.we stopped,cooled down,and after restart,pulled in the clutch,tapped into 1st & when letting out the clutch the wheels turned in reverse.I hit the kill switch & thats when it kicked back & cracked the case.(5mi from day use) thanks fellow banshee freaks
  2. clean the little holes in the brass pipe under the main jet.This will fix your cold start prob.(remove main jet & tap tube out throat of carb.use small 1/4 drive socket.clean holes w/wire)lite tapping,no hitting
  3. maxima castrol 927 50:1. Been running it for 10 years. never a prob.
  4. rockymountainatv.com has it.
  5. not worth the hastle. ricky stator offers a stock stator w/timing plate for 125.00.i have ran it for two years hassle free
  6. mac tools or snapon make small magnets that work fine.
  7. after restart my banshee was in reverse.when i let the clutch out the wheels turned backwards.when i shut off motor, the kickstart stop(inside clutch cover)slammed back & busted the engine case.could this have been caused by the pin not being in the hole in the case?Im baffled
