damshee
damshee's Achievements
  1. thanks for the info, savage there helped me out and set me in the right direction. Ordering New Ball Joints.Sending them to get powercoated again. will updated. thank you I appreciate it alot!
  2. I bought this used shee need to know what type of a arms its running? anyone...... thanks in advance.
  3. Nah....dam stealership didnt have them in stock. had to place an order on rmatv. I had just placed an order yesterday for a new clutch. 2 day air. Had to order separate.....lol they wil get here in 2 days.....then I will run some test runs. thanks man.
  4. Thanks gonna go do some test runs in the morning. I will let you know how it goes. thanks for the help.
  5. Pilot Jet Size is 25. Had to go buy a dam little screwdriver. lol
  6. well I found out something new today reading another post. I have the tors removed. But I have no Idle Screws. I just bought it and finding new stuff. Since it bogs down on low Rpms I should go up more on the Mains??? It runs go on top end. It only bogs when the rpms come down, or in low gear. say as im taking off in 2nd it will bog right before the PowerBand Hits. I know where to buy them but how do I install them...?? It idles Good, starts on the first kick. I dont know why the other owner never installed them. Can I be running it like this???? thank you
  7. Hi, it has stock carbs/ tors removed. 340 mains. Plugs look thank for your help. I believe its running rich. Elevation is close to 4000ft. and weather is around 40-55.
  8. Im also going to take the air box off and just leave the single K&N. If anyone knows whats a good start for mains with just crappy Pro Circuit pipes. Let me know. thank you
  9. Hi, I have a 00 stock reed,stock head at 3700 above sea level. It has some Pro Circuit pipes. What size of jets should I start off with? It Idles perfect....starts on the first kick. but as soon as I let her have it, it bogs and does the sluptering sounds lol. Powerband kicks in......say in 5th gear,, then coming down to 2nd......she bogs. Idles Perfect, just want to know what jets should I start off with. Just bought her used, and trying to get her running perfect. then again it's super cold during this time. Oh and I forgot to tell you felas the major HP's are from the Super Chromed out Boostle Bottle it has" shhhhhhhhhhhhhhhhh Thank You
  10. Stock cyl.s no noss head stock. Stock. What's a good compression reading for a Banshee at 3700-4,104.13 feet above sea level. thanks in advance.
  11. Hi, Planning on buying my first Compression Tester. http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp?counter=3&categoryDisplayName=Tools&fromString=search&itemIdentifier=347021_0_0_&productId=347021&sortType=&parentId=6-10&filterByKeyWord=compression&categoryNValue=100006&navValue=100476&fromWhere=&itemId=476-10&displayName=Compression+Tester&store=1576&skuDisplayName=2+1/2+in.+standard+and+metric+professional+compression+tester+kit&brandName=Actron I saw that one at $39.99 has a couple of different sizes, plus Its the same depth as the plug. I need one for tomorrow, no way of ordering one. What's a good compression reading for a Banshee at 3700-4,104.13 feet above sea level. thanks in advance.
  12. Sounds good. Im going back to old posts taking in all the info. Just trying to decide the hit on the wallet this time around, =)
  13. I was a member back in the day, when he was the man(dan), I havent seen any post mentioning Patriot? I had a motor done by him... Has he stopped or gotten bad rep. Just got a banshee back and want to start modding, Thank's I need a good builder. Just an old member.
  14. Hi, I just purchased a used banshee 2000, I dont really know what a arms it has anyone.? I also have a question, I need to know where I can send my shocks to get rebuilt. I dont really know much about this shee, but its running decent has good compression. 122 on each side. thank you Any info would be appreciated a alot.
