shakar
Everything posted by shakar
  1. bumpity bump>>>>>>>>> i will break up the wp set up, if somonew only needs a single piece.
  2. WTF?? who makes them risers?those are sky scrapers,not risers,.lol..how much taller then stock?
  3. first post jan,16th until now ..im still... in...patiently waiting
  4. ive never used the stock rollers on my -2 swinger or stock size .just the one that goes over the pivot tube and the chain guide one on the back. never had an issue....gooodluck
  5. The Holyman kicker fix. Here's what you do... You go to the hardware store {Sears, Ace etc.} and buy... 1- .25" steel ball bearing 1- M6x40 allen head screw {I'll give instructions on how to find the right one later} 1- #8 spring 1- #2 spring and 1- #86 spring A- Take the kicker off the bike and clamp it in the vice. B- Remove the kicker lever. If the screw is stripped, drill a 3/16 hole into the OTHER end of the screw not into the head of the screw. You should be able to use a screw driver or a chisel and work the screw loose now. C- Be careful to save the stock spring that is behind the ball. {if it's still there} D- Use a Dremel tool to open up the hole in the post big enough to fit the .25" ball into it. DO NOT use force to fit the ball into the hole, you'll NEVER get it out. E- smear some grease into the hole and then put in the original spring {or one of the springs listed above. You will need to cut it down if you use one of the hardware store springs} F- smear more grease onto the post that the lever slips on to. G- Take the cone shaped spring and cut it in half and put it on top of the post with the small end facing up. Make sure the spring isn't so wide that it is wider than the post. If it is, cut it down some more or bend in the part that sticks out. H- Slide the kick lever onto the post and screw in the allen screw to hold it on. ******** Here's where you need to know how to get the right allen screw. *********** When you go to the hardware store, take the kicker with you. You want to buy an allen screw that has a shank {the unthreaded part} that is long enough so that NO threads are in the groove area of the post. To find this out, thread in the screw into the kick lever all the way. Then look into the hole in the bottom of the lever and see if there are any threads visible in the hole. If not, then you have the right one. I- After the kicker is completely assembled, make sure it rotates smoothly. Then cut off the rest of the allen bolt that's sticking out and re-install the kicker. It should last a lifetime. Some guys will re-install an O ring. goodluck
  6. http://bansheehq.com/forums/index.php?showtopic=99361 look for somone with mods & elevation close to yours and go from there.....goodluck
  7. if your plug are white its lean.your wanting a nice allmost cardboard brown color.if your bogging in the mid try to richin up the needle by raising it a step or two. also there's a thread in the jetting section http://bansheehq.com/forums/index.php?showtopic=99361 take a peek there for somone with close mods and altitude . goodluck
  8. this is a great idea & i want a single for each side .................any word from jd on when or if the'll ever be ready to roll & price .....
  9. lookin good but you can get a set of fatty w' silencers for short money .it will be worth it ....big, big diff from the stock junk. also you can mod your stock timin plate to +4 & pop your air box cover off to get a few more pony's goodluck... ...ah and if you do change pipes make sure you jet acordinly...
  10. i also seen a set on ebay.. http://www.ebay.com/...fd3bc97&vxp=mtr or http://www.ebay.com/itm/ITP-SS112-RIMS-Machine-YAMAHA-Banshee-87-88-91-06-SET-4-FRONT-REAR-BLACK-wheels-/150688840099?pt=Motors_ATV_Parts_Accessories&hash=item2315c139a3&vxp=mtr man id jus get some hypers for that price .goodluck
  11. ah man......... thats a bad ass box but to bad it looks like its leaking oil =junk ........goodluck lol
  12. pm sent on pipes ........ smoking deal on the motor.. goodluck
  13. bump i also have a brand new black t.m design case saver 47 $ if your running pods no airbox in the trails i have 1 stainless jd's reg sticker,light plate plate that also covers the pods from mud/dirt pretty well ^^ pic above everything in pics still forsale also .....new blue fuel line,stock intakes ,kickr gear, stock bumper with billit end caps .i planed on driling & tap the inside of the billit caps to hold xtra spark plugs, but never got to it i also have xtra working stock coil and i have a new in package prodeisn billit waterpump with new in package pro design ez drain cover and a billit black pc'd water pump cover .all 3 for 105 to you . pics coming lmk thanks sorry for the messy post .....
  14. pm coming your way.....
  15. most banshee riders love the 34 mm keihn carb .theres tons of info on tuning ,needles.try here http://bansheehq.com/forums/index.php?showtopic=99361 look for somone with your mods,elevation and that should get you close. also look into your needle and jets and im betting itll make a world of diff , goodluck
  16. imo put the money in the motor .fast is better then pretty ....goodluck
  17. pm sent........ i got some
  18. DO YOU EVEN RUN FILTERS??? HOLY SHEET
  19. hell yeah..... ...nice work & video's.
  20. great buyer no probs and no bs............ thanks again
  21. shakar
    Dg pipes
    nice one .set up for draging ?huh .......ah maybe he meant ''draging '' it off the track when it fails. lol
  22. i think he's calling us 180 lbs+ fluffy , big boned guys fat........ lol
  23. 300 main jet dont seem rich but whats your elevation?imo id do a leak down test , if your good there. id fill one hand with new plugs and the other with jets ...its a very ,very slow trial and error thing. but youll be happy when you get it right goodluck
  24. upon doing some research. ive found that this is a lonestar swingarm , so id like 250$ but id rather trade for decent pc's lmk thanks guys
