Emmerrrrr
Everything posted by Emmerrrrr
  1. Sorry Guys been busy I will get all pics this weekend I think i answered all pms
  2. Powdercoated Dark Purple Straight Frame No headlight Brackets 97 frame no title 150.00 Black Seat 30.00 Blue Seat 30.00 One Industries Seat 40.00 Chrome +2+1 A Arms and tie rods With adjustable camber 250.00 Front Spindles Hubs and disk complete 100.00 Stainless front and rear brake lines extender 40.00 Stainless throttle cable 15.00 Dg nerf bars Red 40.00 Two stock gas tanks 10.00 each Duel Pingle Fuel valve 40.00 Front Brake Calipers 50.00 Rear Brake Caliper 30.00 Full Set of stock blue plastic 200.00 Full set of white rear stock front aftermarket race cut 150.00 Full set of fmf fattys 200.00 2into1 Moto fast Stainless exhaust 200.00 2into1 moto fast 40mm Lectron carb complete 200.00 Front Dg bumper Rear Ac bumper Lonestar silvervein +1 roundhouse style carrier swingarrm 350.00 Extended Chrome Axle 125.00 Lonestar stock length steering stem 7/8 bar chrome 100.00 stock steering stem 25.00 pro circuit slip ons 150.00 Twist Throttle 20.00 Renthal handlebars 20.00 Stock complete air box 60.00 Rear TCS shock needs bushings 200lb rider 150.00 Blue nerf bars 40.00 Propeg nerfbars 50.00 Complete bottom end part out cases top and bottom 125.00 two cranks 100.00 Each complete transmission 150.00 Radiator 70.00 one cylinder 60.00 and some other small parts if need anything else might have it all parts are obo
  3. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220666710486&viewitem=&_trkparms=tab%3DSelling Heres the ebay ad
  4. 1993 Yamaha Banshee all fresh this is a tight banshee all new bearings seals bushings the kicker don't even rattle 4 mil stroker crank hot rods .020 bore with 795 series piston chrome chariot head with stroker domes 24cc v force 3 reeds 4 mil port from herrs jugs 2 into 1 stainless steel moto fast exhaust ( really needs some t5s to wake it up) powdercoated black cases powdercaoted candy blue cylinders this motor has just been gone through all new seals 5 mins on motor total just did the initial break in warm up 15 mins 3 times and check torque on head bolts fresh powdercoated blue frame white fenders blue tank and rad shroud chrome +2 lonestar swingarm with roundhouse carrier billet water pump impellar 4000.00 Youngstown ohio can't get pictures posted if interested i can email then
  5. any pics of the pro circuits
  6. Heres the mods aggressive trail port, 4 mil crank, 2 into 1 pipe, v force reeds, kn filter with lid got in the middle, coolhead with 24cc domes, stock carbs Im in ohio i thinks its 800 above sea level tempature is 60-70 out right now Right now I got stock pilot it screw out 2 turns 300 main needle all the way up the richest Its got hesitation through out the powerband Just cant get it tuned in Thanks for all help
  7. I got it guys thanks i forgot to tightem the inside adjustment
  8. I got it all back together Thanks to you guys Thanks I appreciate it.. one last question i don't have no clutch the lever is just free brand new clutch cable fluids all good.. if any suggestions thanks
  9. This is all needed to finish up my build in the morning.... I need to know where all the radiator and overflow hoses go off the overflow bottle and which ones tie in where on the motor a picture would be appreciated if anything.. I went all through my clymer manual and couldn't find anthing Thanks FOr all you help I will get pics up tomorrow if everything goes good
  10. Thank You appreciate it Does the vaseline trick work
  11. i just picked up a chariot cool head.. this is my first banshee.. im not sure where all the o rings go if anyone can help me out.. i see the 2 big ones go on the outside groove... I hear to put vaseline in the groove to hold them in place.. Any help would much be aprreciated thank you
  12. Would you do 200 shipped
  13. Interested but need to see some good pics hard to buy something without seeing them
  14. 4 mil long rod just some bolt ones 28 pwks vforce wanna stay on pump 93 getting ready to order stroker cut domes which ones to go with Im southeastern Ohio
  15. Stock crank Out of an 02 Excellent condition bearings are smooth no rod play.. First rebuild on the motor needed a top end low compression so I put a 4mil crank in Taking Highest Offer... 25 Shipping on top of offer.. Paypal Please
  16. I Was working on getting my bottom end together just threw a 4mi hot rods stroker crank in it .. now im thinking about the top end its .20 over...I dunno if i should send them to get ported or order the cheetah cub cylinders.. wheres the power hit on the cheetah cub cylinders 68mm would be the size.. what other performance mods do you think I should go with for trail riding and hillclimbing back in the woods.. For example whats a good cool head, what reeds, what pipes, what carbs,, Thanks for the help on the build this is my first banshee bought it blown up and almost back together
  17. .020 Stock yamaha banshee cylinders. just a fresh bore and hone to .020.. These cylinders have not yet been ported.. Top End Kit from Wiseco. Includes pistons rings wrist pins and gaskets Ready to bolt together 600.00
  18. anybody have any chrome a arms
  19. I will have them ported and run the stroker domes... what I was asking if the clearance for the pistons be alright since Im switching pistons from the regular pistons to the 795 series to make up the long rod
  20. I just got my cylinders back from the machine shop I got them bored .020 over and honed..I ordered a wiseco top end kit and brought him the pistons so he could match the clearance up.. I Think the clearance was .0003..Now I was thinking of going with a 4mm Stroker.. To do this I would have to sell these pistons and order the 795 series.. Now if I Do this will my clearance on my cylinders be messed up or will i be alright to just bolt in and go
  21. All these companys on ebay that make swingarms all do the stock style carrier...any good companys out there that make the round style houseing carrier for a reasonable price..I really didn't want to pay almost 700 for one
  22. Wanted aftermarket swingarm stock length any color don't matter
  23. I ended up getting a bolt that fit in there and welded a nut to it thanks everyone
