robert0762
Everything posted by robert0762
  1. Ttt Sent from my SM-G900V using Tapatalk
  2. Obo Sent from my SM-G900V using Tapatalk
  3. Got A Set Of graydon proline pipes for sale 65 bucks plus shipping takes me they are in ruff shape 443 617 3865 Sent from my SM-G900V using Tapatalk
  4. No rear hubs Sent from my SM-G900V using Tapatalk
  5. Ttt Sent from my SM-G900V using Tapatalk
  6. Panty dropper and coil sold Sent from my SM-G900V using Tapatalk
  7. Throttle sold Sent from my SM-G900V using Tapatalk
  8. No flywheel Sent from my SM-G900V using Tapatalk
  9. Yes I have clutch hub Sent from my SM-G900V using Tapatalk
  10. Bump Sent from my SM-G900V using Tapatalk
  11. Rear brake caliper sold Sent from my SM-G900V using Tapatalk
  12. I have a seat thanks for the replys Sent from my SM-G900V using Tapatalk
  13. Text me again please Sent from my SM-G900V using Tapatalk
  14. Cylinders sold Sent from my SM-G900V using Tapatalk
  15. Will trade for a good seat foam or whole seat just need good foam
  16. Clutch springs sold Sent from my SM-G900V using Tapatalk
  17. All prices are for parts only. Shipping will be added. We all know what flat rate usps boxes cost. Will do package deals.will sell whole lot . yfz450 spindles hubs rotors 40 one hub is missing spacer in between bearings banshee hub w/rotor 15 clutch fibers and steels two full sets one stock the other ? 10 head 10 kicker gear 15 idler gear 10 crank gear 10 clutch nut washer and bearing 20 sprocket nut and sleeve 10 crank nuts both sides and keys 20 trans clips 5 presure plates 15 clutch hub 15 dual stage reeds 30 clutch arm 10 sprocket and hub 15 brake hub 15 cylinders 65.00 need a bore 80 shifer 10 light and run switch 20 nuetral sw cover 5 shift shaft 10 shock good 50 water pump cover 5 lights for parts 10 k and n filters for stock or 28 mm carbs 15 upper left a arm 15 rad cover w panty dropper 20 front brake master cylinder 10 rad hoses all for 10 rear linkage 40 steering stem mounting blocks 15 tail light 10 rear brake lt switch 10 clutch cover 20 flywheel cove 10 tie rods stock 10 foot pegs w bolts 25 throttle 25 front brake line lower one 5 two stock frames 100 each carbs stock 50 for all clutch springs heavy normal and stock 15 for whole box front fender supports 20 timing plate 5 coil missing one cap 10 rear chain guide 10 443 617 3865 text w any questions rob paypal is [email protected] leave a note saying what its for
  18. Price on seat shipped. Pics please ? Sent from my SM-G900V using Tapatalk
  19. I need a good stock seat foam. I will take the whole seat also . Let me know what you have. Please respond with pics and price Sent from my SM-G900V using Tapatalk
  20. Pic of seat and how much Sent from my SM-G900V using Tapatalk
  21. Sent you a pm Sent from my SM-G900V using Tapatalk
  22. Seat ? Sent from my SM-G900V using Tapatalk
  23. Rear brake mount the bolts up a 450 dual piston caliper. Sent from my SM-G900V using Tapatalk
