motodrumer58
Everything posted by motodrumer58
  1. That's the method Im using!!!! I just dont understand why my R turns on a dime and the shee won't
  2. I have -2 swinnger R1 shock on the rear and blaster shocks on the front. Sway bar and front lowering kit. My 310R turns effortless. Im running Flat track ice. Any suggestions?
  3. My buddy with the cheetah cub went to practice today (I stayed home) and blew a clutch a 3rd gear. So he has to drive an hour home and bust a move before leaving tomorrow a 6am..
  4. http://freezexfest.com/news/2010/01/thursday-video/ Gonna rep the 2 strokes at the AMA Ice Nationals in Mt Plesant MI. Im Running a Honda 310r against the 450 and under 4 strokes and running my banshee in the open class. My friend is running a banshee as well with a dyno'd 94hp engine. Im just running a some port work on my shee. We are going to try to put one of these babys on the podium. 2 Stroke 4 Life
  5. Me and my banshee get 2nd place finish in the open class at port huron MI MC 2 stroke 4 life
  6. I broke down and bought a new 520 gold and cut her down. I am going to change the chain with the gearing changes.
  7. Tha gize fram TDR RDZ or Trinity are buzy makeing HP and $$ not tahlking smack on heeere...
  8. I put my -2 swingarm on and I cant seem to get a chain to tighten it is either to long or to short. Anyone have one on there ride that can tell me how many link chain there running? thank you
  9. Were you limited to the number of studs you could use? thanks
  10. I just watched the viddy. That was cool as hell. My vote for banshee video of the year!!!! Hats off to ya.. thanx
  11. The studs will be an unaltered #7 to #10 hex headed screw with no more than one slot, uncut, no drilling or hollowing out of the head and the screw to be flush into the tire tightly ,not using a shim or washer to hold it out from the tire. The screw head cannot exceed 3/16” above the tire. This is the rules for ama d14 I am using kold kutters
  12. Right on Bro...... You got to let me know your tire and stud set up. I would give my left nut to pull off the line like that!!!! I want to do what you did to the 4 strokes here in Michigan
  13. r6 all the way around
  14. I am still working on the sway bar fitment. Might not need it
  15. I am waiting for the ice to freeze all the way here in Michigan. Last year I used stock shocks with a bottom mounted lowering kit and a sway bar.My set up right now is sporting R6 shocks all the way around. I have the sway bar mounted but not hooked up. I will bring last years set up and compare once the lakes are ready. If I can find a cheap pair of blaster shocks I am going to try those as well. I race a TRX250r too, 300ex and sway bar is the set up this yearso far. My problem is not hooking off the line.
  16. they were on stock quadzillas
  17. jarm Frame $220 shipped pick up from nearest greyhound terminal 250 with swingarm 50 swingarm frame is straight no cracks or rewelds
  18. keeping the bolts for a build
  19. 60 shipped 2-3 days for the lights
  20. Before I put the parts on ebay. No motor everthing else is stock. Let me know what your looking for. pics available Frame jarms steering stem swing arm axel motor mounts radiator seat rear bumper tailight white uncut plastic tank air box fair older tires and rims blown rear shock front shocks brakes all 87 jarm
  21. 2-3 days on your stator thanx
  22. I really dont like the look of some builds,that get everthing on there bike the same color. I have a couple of days left before my dude can put in the oven. I only gave him the frame. Should at least do the hubs? I went with a New bright {but not neon green} with Royal blue and redish orange flake. This is my third build and wanted to do somthing colorful. The first two builds were stock colors. What do you think?
