johstoncounty banshee
Everything posted by johstoncounty banshee
  1. The reason I was asking what specific bike the fibers came from was I was trying to find them locally. Trying to get it back ready for the track Thursday. My barnett didn't last very long.
  2. Well I finally got it almost figured out. I seen 20lbs of boost when the crank decided to come apart. Then come along a divorce and my wonderful lil girl. It will be going back together in the near future. I done away with the 2 pipe setup and went with the 2 into 1 along with nitro that was the ticket.
  3. Ok I seen where someone said 95 fzr 1000 and also a 94-95 fzr 600r
  4. What year and engine size fzr clutch fibers work in banshee?
  5. I've got a set I think 9195240078
  6. I need a good set of cases no chain wack. Thanks txt 9195240078. Or email
  7. OK thanks the guy I got them from said k&t set them up.
  8. Does anyone know the size of the barb to male thread fitting that goes into the float bowl. My chain snapped going down the drag strip and broke it off. I think its 10/32 is that correct.
  9. Does anyone no the size of the thread on the hose barb to male thread that feeds the power jets. Also where I can get them?
  10. Have you run your bike on the track yet
  11. 4 mill cub
  12. Yea I will sell them
  13. Want to trade 36mm air strikers for 38 or bigger carbs. This are gas carbs. Would be nice if they where alky carbs. Might add cash.
  14. Naw that's definitely not the problem. Something like tune or low on compression more than likely
  15. Something is way wrong if its a 421 bogging with just some bolts in the tires. 40 mm carbs are probably way to big for your motor if you are just running race gas. Was it running on alcohol before?
  16. Is the bike low on compression. What are your motor specs?
  17. Thanks I will let my friend no
  18. Who cut the transmission
  19. i am checking all that tonight after i do a test run on it. i no bwtter than running it lean . thanks for the reminder
  20. right now its a 150 but i am sure it might can go up. it was to late for me to ride it last night.
  21. I put a 48 pilot in that's pretty dang close
  22. Yea I tried a 55 that's way to fat. I am going to try a 48 I am headed to get them now
  23. cleaned up the casting thats it. 600ft
