2SLO
2SLO's Achievements
  1. does it usualy smoke alot durring break in?
  2. figured it out.. the clutch disc's were rusted to the plates.. durrr.
  3. are you pretty good with these things? im in st peters and im having a hard time..
  4. i guess its trashed.. it just wont disengage..
  5. yeah, the arrows line up when its disengaged... i loosened it further, and i can push the lever with my finger until the arrows line up..
  6. ill go check it now.. where is ravenwood in conjunction with st. louis?
  7. I finally installed my chain, and tried to ride my banshee (that runs like crap). When i pull in the clutch and pout it in gear, it lunges forward and dies. The clutch isnt fully disengaging. I adjusted the cable all the way out, and still nothing. Any ideas or is this a common problem?
  8. i hope i dont have to buy new carbs!
  9. alright, i cleaned the shit out of the carbs and put 27.5's and 290's in because of the procircuit pipes. now, the RIGHT side pipe gets warm, pings, and smokes its ass off (super rich i think) and the LEFT side never gets warm at ALL and dosent smoke untill you rev the pissout of it! GRRR this is starting to get old.. tomorrow ill put the stock pilots in, and see what it does. any idea on the one side smoking and one side not???
  10. alright. i put the choke tube on there, no luck. still needs brake clean to start, then while its running, if i spray shots of brake cleaner into the left carb, it stays at its normal idle and kees running, but if i spray it in the RIGHT carb, it idles up like crazy! the left pipe gets way hotter way faster than the right pipe. any ideas?
  11. choke tube is NOT there. ill grab some vacuum hose from work today and get one on there. ill report back tonight!
  12. ive been been working on performance cars and boats for 8 years as my profession, and i cant get a frickin banshee to run?!?!?! anyone live in the st. louis area want to help me out?!
  13. awesome. thanks alot man. im going to take them apart again tonight i think..
  14. ughhhhhhhhhh
  15. anyone?!
