#1JUANstunna
Moderator
    44
Everything posted by #1JUANstunna
  1. I prefer stolenatvparts.com and junkatvparts.com.
  2. It wasn't a failure, it was that a bunch of whining ass people wouldn't stop bitching cuz they didn't have their post count. 500 posts are a little crazy but something needs changed. I don't have a solution so I'm not going to bitch, much.
  3. Copy and paste the IMG code in PB and it should work fine. It looks like your IMG code isn't formatted correctly
  4. Safari looks just like the regular site and works fine. I use tapatalk to upload pics. Other than that I don't use it
  5. Well crap!
  6. What happened to the orange? or am I in the wrong thread?
  7. Nope not on tapatalk, that was on safari, in the full version of the site. It looks exactly the same as when I'm on my computer This was sent from my iPhone 4 I actually typed that time, cuz I have that option turned off.
  8. Works for me ladies. Just push multi quote on each response. Go to the bottom and click more reply options and there are all the quotes. This was sent from my iPhone 4
  9. So did the stator cover ship or not?
  10. He doesn't know what the multiQuote button is or he just wants to boost his post count. The more posts you have the smarter you are.
  11. That's when Matt starts taking advantage of you isn't it.
  12. http://lectronfuelsystems.com/docs/Tuning_Instr.pdf Click and learn
  13. I don't, I have a spare just in case.
  14. He's busy building a space shuttle for NASA.
  15. No one is bashing yet. Just giving you a rough time. 9 post newbie better get used to it around here some of us are a rough crowd to get used too. My guess is that the sound is actually in the 2-1 pipe and not the silencer
  16. Dude I cut mine and almost hit 100mph
  17. The voices in his head.
  18. Appearing to lift at the same time and syncd is two different things. I agreed that you are lean but until you get the idle screws its going to be hard to make the proper assessment of your problems.
  19. Carbs are probably probably out of sync too
  20. If it was me I'd pull the carbs, clean and inspect them. Bump the pilots to 27.5. Install the idle screws. Reassemble and adjust to factory specs. And start from there. Making sure the cable is properly routed, adjusted and slides are seated. Are you trying this with the air box in place or not
  21. Tors or deleted? If deleted make sure your cable is all the way down in the holder and its adjusted correctly. Are the slides in the correct way with the cut out in the rear? Are you sure you just don't have the idle turned up too high? You should think about syncing the carbs while you're at it too
  22. I like the paint scheme idea. Does the orange have a metallic flake in it or something? I'm on my phone at the moment and can't tell.
