4StrokeKilla
Everything posted by 4StrokeKilla
  1. I have stock cylinders im willing to trade
  2. Well imma replace my plugs But do you kno anyhting else that could be the problem cause i dont wat her to blow on me or anything that ill have to waste big bucks on to get her fixed
  3. :sad: ok i took my shee out yesterday and it started up right away and everything i let it warm up then got on it and took of but when i would punch on the throttle it wouldn't responed right away then i shifted and it sounded like if one of my pipes was only working the other one just didnt work :sad: so i tried it again and they both worked but after a while it kept on doing it again Then when i left it there turned on one of my carbs started to leak gas but big time though HELP HELP :shrug: Does anyone now what could be the problem? :shrug:
  4. If you still got them will you take $200 for them? :smile:
  5. ok i took my shee out yesterday and it started up right away and everything i let it warm up then got on it and took of but when i would punch on the throttle it wouldn't responed right away :sad: then i shifted and it sounded like if one of my pipes was only working the other one just didnt work :shrug: so i tried it again and they both worked but after a while it kept on doing it again Then when i left it there turned on one of my carbs started to leak gas but big time though HELP HELP :sad: :shrug: Does anyone now what could be the problem? :shrug:
  6. Im intrested in this I've been looking every where for some cheap ones Do you still have them?
  7. thaks for the info :biggrin: and do you know how much a dune port usually cost?
  8. so i should get smaller size tires? but is there any sprocket ratio that can give me a better take off but same or almost the same top speed?
  9. so 14-44 for gearing is a good way to go right? but what about if i go with 12-44 what diffrence will that make on it with 21" haulers?
  10. im running stock ones and the take off feels slow and the top needs more speed to
  11. No its ot a 4mil no port job ad no swingarm but im planning on getting it ported this summer and gettin a +6 swingarm what kinda porting is good and not so expensive?
  12. What else do you need to know?
  13. hey i been looking at forum about people putting diffrent sprocket and now im wondering what size of sprockets should i get? im 180 lb i have CPI drag pipes outframe adjustable timing plate K&N filter jetted and i have 22in. 10 paddle haulers and i only ride in the sand and i want something so i could race and have a good take off and still have top speed though?
  14. well ive none how to use a wrench since the age of 9 so go and learn how to relax dog cause u got some anger management puto
  15. and how do you use the flywheel puller?
  16. and what are the right tools
  17. well its because i live out in the country and its like an 1 hour 1/2 to go into town and buy it thats why i wanna know if there is any other way of taking the flywheel off without using the flywheel puller
  18. i need help on how to remove the old timing plate if there is a way without using the flywheel puller thing?
  19. oh ok then so running it at +4 will be just fine then
  20. so i should put it at +2 with the boost bootle and without the boost bottle at +4 and how will i know thats not the right degree
  21. just jetted carbs and drag pipes
  22. does anyone know where they could chrome out parts here in california?
  23. well yea thats what i wanna put but i really dont kno bout thats kinda stuff what size of port would you suggest me to put?
