groutman
Everything posted by groutman
  1. groutman
    tires
    thats what i thought but it says they are for dirt flat track
  2. groutman
    tires
    would these be any good as i only drag this banshee
  3. groutman
    tires
    i just won a set of duro tires and i can pick wich ones i want any suggestions that would be good for dirt drags
  4. did aplug chop yesterday didnt see any ring it was all white got 360 mains clip in 4th 1 1/2 on air screw has a bog right before powerband drag port shearer inframes v force reeds kn pods stock carbs 1800ft 40-1 mix
  5. i have had good luck here www.jetsrus.com
  6. i got a namura .60 pistons 130.00 rings 34.00 top end gasket set 11.00 + shipping
  7. it runs pretty good i still have to fine tune the jetting kinda doggy till powerband kicks in i got needle on 4th clip down and 340 on mains
  8. i dont have the money for new carbs this year so i got keep these for now
  9. well i got it put together this past weekend and it started first kick couldnt believe that now i need to do the jeting can anyone give me a starting point it has a drag port,vforce reeds shearer inframes,stock carbs with a 200 main,k&n filters no air box,running blue marble at 40-1 ratio pump gas hope thats enough info also what would be a good gear ratio to start with 500ft dirt track thanks
  10. i got a set of Shearer inframes coming geting ready to put it together this weekend
  11. wife said my a-arm came thanks for the fast shipping now i got to get home to put it on
  12. got my cylinders today 300$ gone on that part{piston,rings,wristpin bearing and bore}
  13. i will have to get back to ya on that gotta see how much my pistons and bore cost
  14. pm sent
  15. is it easy to do i found some for 35 on ebay sounds pretty cheap
  16. i got a set of vforce reeds coming should i put in one of those adj. timing plates
  17. timing plate carbs and head any suggestions i was trying to get some used pipes found some toomys and fmf for under 300
  18. yea i thought i would leave the chassie stock for this year and just get it running i just dont know what parts to put in it so it will run decent
  19. well i just want to get it running this year
  20. stock
  21. well i finally got another banshee after selling my last one i would like to build it for 500ft dirt drags just to have some fun with i would be riding it only on the strip the motor needs a new top end now. i picked up a set of drag ported cylinders what do i need to make these work? i need to get some pipes as it is all stock now i have some vforce reeds and a assortment of sprockets i need to keep the costs down for this season anyway {under 800} not including pipes thanks for your help
