ItzaBansheeBitch
Everything posted by ItzaBansheeBitch
  1. I got some Mint 2001 Complete spindles and hubs for sale. 75 + shipping
  2. Bike is in Texas here are the mods 3 sets of wheels Knobbies and paddles 2 sets of plastics Blue / Black CPI Pipes been welded .20 top end dune port Cool head V-Force 2's Graydon 2-n-1 36mm PJ AC Black line pro pegs Azonic bars Twist with scott grips ASV clutch lever Billet Neck, Bake rez Stock or -1 (cant rember) swinger New bearings in carrier New brakes Parking bake B/o Hella lights Extras 200w Rs stator Stock new style CDI Stock swinger and carrier Stock carbs Spindles and rotors brake / clutch Levers hell lots more Just let me Know
  3. here she is this weekend. I will take a pic of whatever you want!!
  4. ANY Parts you need off of my baby!! 2001 Banshee Tons of bolt on shit just tell me what you need, Or buy the entire quad 2,500 TODAY ONLY going up tomorrow on Ebay!
  5. Best Fuggn carbs for the money!! i had the 30mm's. They are CPW carbs but have OKO on the body, Takes all Keihen parts. GOOD SHIT MAN!!!!
  6. I need money!! Baby Boy DUE in less than 2 weeks!! so here we GO!! NEED ANY PARTS LET ME KNOW!!! 2001 Banshee .20 over, Trail/Dune port, cool head, stock bottom end, R6 clutch, 13 tooth sprocket. Graydon 2-n-1 intake pollished, 36mm pj carb. Motor runs good and is in my quad right now. I just finished building it, now I need the money. $900 plus shipping. OBO CASH TALKS!!! Pics from last weekend
  7. I Call BS. Pics or Ban. A turbo is a COMPLICATED system, Not just a bolt up and go. Your full of shit. Just my .02
  8. going left to right or like this >>>>>>> or this <<<<<<<<<<<<<
  9. well thats bout it. Do you run 4-snows backwards? They look like the would bite better run backwards.. Also what psi do you run them at?
  10. get the T5 pipes with the K&N air filter kit WITH the jet kit and take the top off the box. You will walk on him. Or get used pipes and kit and buy a $300 port job to make a killer package. But it will be tight on 700 bux. My .02 port and fmf pipes.
  11. Complete trans and forks???
  12. Bout says it all I need shift forks shipped to Texas.
  13. Sounds like shirt slap. Have you checked the rig gap clearance? have your jugs checked, who ever did your work might have gotten a little out of spec.
  14. Is your air filter clogged? 2-strokes MUST fire if they have spark and fuel. They are super simple and only have a few problems that can prevent combustion. Let the plugs dry out before you reinstall them. Pull your air filter off and try to start it again.
  15. Have you pulled the plugs? Are you getting gas? plugs will be wet if you have kicked the shit out of it with no ignition.
  16. Do you still have the T.O.R.S and parking brake on? If so pull that shit off. or just unplug it all and see if shee will start.
  17. SNOP!!! Ok I got 180 main, DEI? (DEL) on the top clip, 55 pilot jet. Good on the start up, 0-1/4 is good Fall and gargles for a sec at 1/4-1/2 and runs like a raped ape on out. I have tried every clip on the needle and it only gets worse. Is my pilot to big or do I need a diff needle?
  18. Make sure you have the Flywheel on the shaft with the Key ( moon key, shear key) locking it correctly. You can have all the spark in the world, but if the flywheel is out of time you will not get combustion. the piston has to be in the correct phase of the stroke. Check that then get back to me.
  19. DAMN!! Well what do you think about the compression? 135 psi stock stroke .20 over 17cc Cool head. Might as well call jeff and send it away and get her 4 mill'd
  20. Sorry they are sold.
  21. thats whast i was thinking. I cheched the oil No metal bits, just flake from the clutch. I dont wanna split the cases agan this year..
  22. well took the shee for a good hard blast and noticed at low RPM I could hear some popping in the trans. So I haul ass kill the bike and throw it in neutral and man o live it FUCKIN LOUD!! Bike is kinda hard shift when under power (started missing Alot of shifts) So whats you guys ideas? Did I shell a trans some how? chain and sprocket are new, chain was way tight I will add. What do bent shift forks act like? I do shift w/out the clutch from first up. I also got 135 psi with 17cc domes, Rebuild time? Just starting to be a shitty bad. Thanks for the help
  23. Any of you guys know a good website to go to for track locations?? Do yall know of any tracks?? ANYONE??
