I'm in the Denton area. I have a little "playground" in my sub division that I ride at and I've got a buddy that has about 400 acres that ill ride around.
I'm looking for some pegs that lower about 2". I've heard blaster pegs work. I'd also like some nerf bars and metal heel guards. I don't know if this combo is possible. Want to see what's out there. Some minor modification shouldn't be a problem.
Do you have any more details how you shortened the harness that much? I don't see the voltage regulator and I'm guessing that's because you are not running lights. I'm trying to retire mine now and am having problems. I have a Clymers though.
That's what I ordered but I ordered it to move everything up front. It looks to be a nice piece but kinda spendy. I ordered it on 11/20 and was told it would take days to get to me. As of today I still don't have it. If you need it fast I wouldn't order order it. If you can wait then I would suggest it.
I'm needing new or used rear brake hub. I bought a new rotor and set of pads and went to change them out and found that the allen bolts were stripped. Please let me know what you have thanks.
1) What type of aftermarket exhaust do you have? FMF Gnarley with power core 2
2) What type of airfilter do you have? Pod filters
3) Are you d) no airbox at all
4) What is your elevation?600
5) What size pilot jets are you using? Stock
6) What size main jets are you using? Stock
7) What temperature is your Banshee jetted for? Don't know.
8) Do you have a port job? No
9) What kind of carbs? Stock
10) What size carbs? Stock
I'm trying to get an idea on what size jets i need order. I'm thinking 27.5 and then 270-300. How does this sound?
Updated list. Thanks to all for the help so far.
K&N pod filters
Timing plate
Coolant impeller
Different handle bars
Skid plates
Vapor trail tech
Coolant tank bracket
Before I go and buy this stuff new I was wondering of any had any of it for sale. New or used. If so please send pictures and price with shipping to 76227. [email protected]
Hide a key bracket
K&N pod filters
TORS delete with idle screws
Timing plate
Coolant impeller
Skid plates
Vapor trail tech
280, 290, 300, 310, 27.5, 30 jets and rebuild kit x2 for stock carbs
I picked one up today! I'm going to try and tear into it this weekend. Clean things up, carbs were cleaned I was told, need to check all the bushings real good and lube things up. I was told it was sitting for awhile.
