daweaseltoo
Everything posted by daweaseltoo
  1. pm sent on timing plate..
  2. I'll take the pingle...pm sent
  3. are the shearers small flange? what is the overall condition on a 1-10?
  4. how bout these?
  5. At this last race, i think there was only one bike that turned in the 3's and it was a triple. some dm's were running 4.0?'s I just bought some 14 pdl ext i can't wait to try out. I'm spinning bad at the start and need to do something with my clutch too? I think this conversion in the far lane ran 4.2
  6. any idea what i should start with for arm weight? or is that a secret
  7. i don't know my arm weights. i have ran it will all oem springs and though i was slipping too much (seat of the pants) and no times...... so i put in 3 stiff, 3 oem. pic is with all oem springs and yes that's me in last...lol.
  8. Yeah, that's what i'm thinking too. lowering my 60ft will help my et and don't worry about so much about mph. guess it's time to get the wallet out and get some tires. i try tires first and then work on the gearing.
  9. i think i'm close to being maxed now with 15/42, so with a 16 or 17 i might be able to get it into 5th but i'm sure it won't be maxed out. will be easy to try though just to see if it makes a 60ft difference .
  10. do you get into 5th with a 16 or 17/44?
  11. k i'll try the 16 on the front, i don"t know where that will put me at the finish in 4th or 5th but will find out.
  12. Yeah i launch in second and get it into third right away, no bog at all. i might be able to launch in third but i thought that would blow the tires out worse? i'll keep my eye out for some 14 extremes for sure and see if i can stiffen up the rear shock some more too. it's weird cause it use to lift with the stock soft shock on, but now that is lowered with the stiffer shock, doesn't lift at all?
  13. first time to a 300ft sand drag race and i can't seem to get launched. the track is all sand, no dirt mix. my set up is a 10 cub, 150 lb rider, 15/42 gear, stock frame, +8 swinger, +2 a-arms, lowered with R6 rear and ex300 front shocks. i started with 72" ro 12 paddle extremes and then tried a buddies 72" ro 13 paddle extremes. my 60ft times didn't really change much from switching tires. my et got .056 quicker though. i've posted a couple pictures and time slips, hoping for some advise on my set up. i'm number 24 on the slips, orange in the pics, my kid is #28 on a 7mm stock cylinder we switch tires on his too for comparison. something else too, my front never lifts at all now since i switched shocks to lower it? i've got a ton of times slips, no 60ft time quicker than the one with my son riding (1.759). http://i1129.photobucket.com/albums/m501/daweaseltoo/DSCN6394.jpg http://i1129.photobucket.com/albums/m501/daweaseltoo/DSCN6388.jpg http://i1129.photobucket.com/albums/m501/daweaseltoo/sanddragtimes032.jpg my kid (115 lbs) ran 60ft in 1.759 and a 4.30 on #24.
  14. I just installed a R6 shock with a red spring, vertical reservoir. Lowered it 8 inches with a 8 over swinger. Had to make some bushings for the bottom bolt/link.
  15. daweaseltoo
    Toomey T5S
    I have some t5's. they are used and not new, but in good condition. here's a bad pic.. http://medford.craigslist.org/rvs/2337568745.html
  16. i have some t-5's w/silencers, but no springs or clamps though... i can work with you on the shipping if interested. http://medford.craigslist.org/rvs/2251210908.html oh, i have a front bumber too. not sure of brand but can get you a pic....
  17. i have a 6 over for sale... $139 or trade? http://medford.craigslist.org/mcy/2275389283.html
  18. I've got a set of 30 pwk's if you're interested? http://medford.craigslist.org/mcy/2275389283.html
  19. I got one too from that guy..i checked into it and i think most of those tiawan crank parts come from competitive crankshafts out of los angeles. i order mine with upgraded center main bearnings, 10 ball roller bearing, tz bearing and different rods. i check mine and it was .0015 true. just stuck it in the cases today with no issues.
  20. I just got mine back from greg. sent him my dunable 1-4 m5&6..had him convert it to a n1-5 ...all good! always returned my emails and phone calls. no worries.! i'm going to send him my other one for the same make over.
  21. no..what carbs do you have on there now?
  22. i have some pwk 30's....plus $10 shipping. http://medford.craigslist.org/rvs/2251210908.html
  23. i have some t-5's and some pro circuit's....add $25 for the ride. http://medford.craigslist.org/rvs/2251210908.html
  24. Yeah that! ran mine over Prez weekend.. air temp was about 15-20 degrees colder than normal..went up two sizes on pilots and mains from cpi's/colder temp. hit a lot harder than the cpi's...ran both cpi's and snipers against some of my buddies...really hard to say, but sniper's may be a little stronger, a length or so in 500-600 ft... ran on a re-sleeved big bore 7mm stock cyllinder and not a cub, so not the ideal application...my 10 cub is still a work in progress.
  25. how much for the crank?
