97banshee
    97banshee Works shocks UNI air filter pro circuit silencers Nerf bars Handlebars & grips
97banshee's Achievements
  1. Need a stock banshee carb for the left side, PM me if you got one with the price. Thanx
  2. I will trade you my yellow uncut fenders. great condition.........all besides one small spot.
  3. When i first bought my banshee an we was towing it home on the trailer, we stopped to gas up an i wanted to start it an i kicked it a good 50 times an not 1 hit then i let it dit for a minute pulled the choke all the way out kicked it 5 times an she fired up.
  4. The carb looks brand new on the inside, i cleaned every single part of it, i pulled them 12 times each in hope of adjusting the float an checking other stuff ect..........im putting new plugs in it tomorrow, hope that does the trick.
  5. The stinger pipe fell off the left side it was to hott to put it back on so i set it on my nerf bar an was riding my banshee back home i decided i would see how it sounds without that pipe if i was to hit the powerband, so you know i was going down the road it was running boggish like it has been ever since i got it an no power when on the powerband well anyways it was loud then i hit the powerband you know not much power likes it supposed to have an it got quite, it quit firing on the left cylinder i figured i would put the stinger pipe back on that side an take the one off the right side an seen if it did the same thing, well i went up the road an back down the road with the right side stonger pipe off an that one never cut out. So there for it has crossed my mind its not firing on the left cylinder at high RPMS which is also the reason that when i hit the powerband i really don't have any power. Every now an then when i'm riding an its on the powerband it will have a sudden burst of power then stop again which means the left cylinder started firing again then stopped. Get what i mean now? Sorry if i was talking noob. hahahha
  6. No no no the peice that connects the silencer an the head pipe fell off, ok well i put it back on an took the right side off an i could hear the exhaust all the way up the road where the left side quit making noise so it has to be cutting out.
  7. I was riding my banshee just a few minutes ago an the pipe that connects my head an silencer came off an it was hott so i couldn't put it back on so i was riding it to the house an i got on the throttle an you know i said it was boggish an all that well you know it was loud an i was going down the road then all a sudden it got quiet an not much power like usuall so i think my left cylinder is cutting out at higher RPMs. because the left pipe wasn't as loud anymore it just got quite but still running on only the right side i belive, so maybe it isn't my carbs its my left cylinder cutting out. any ideas on what i would have to replace? or check?
  8. What do you want for the needle seat an valve from the left carb if it doesn't leak.
  9. We got the same banshee, Lol
  10. What do you want for the pipes?
  11. i can buy them new for 10 dollars more.
  12. I'm in need of needle valves an seats for the stock carbs that doesn't leak if you have some for sale let me know. PM me a price or post it on here. Thanx.
  13. i got a stock killswitch an key. PM me if interested or post back here.
  14. All blaster bumpers are the same. It's in good shape. Sorry no aftermarkets just what's listed there. I can gets pics.
  15. Timing could be off by a couple teeth on the cam gear, or you could have water/dirt clogging a jet.
