boomadge
Everything posted by boomadge
  1. Slight bog usually means its a little rich on the pilot, 0-1/4 throttle tells me that you need to raise the clip 1 notch on the slides (wich will lower the slides to lean it just a tad). you will have to most likely re-adjust the the A/F screw. If it makes it worse then the "bog" is actually a "hesitation" and you will have to lower the clip down 1 notch from the original middle notch (wich will raise the slides to richen it slightly) Again adjusting of the A/F screw will be needed. Any one else care to disagree or add something ? Good luck
  2. Airscrew out is leaner(more air) Airscrew in is richer(less air) Correct me if i am wrong.
  3. Have had this happen to me outta the blue as well. Is it possible the water is being vaporized as its entering the carbs and therefor displaceing the octane of the fuel plus distrubting the mixture making it lean out?
  4. Its all good I was just putting up what I have for something to compare to. I notice your in cuyahoga falls, I lived in ravenna and worked in bedford heights for 13 years. Hope you get it figured out.
  5. I'm at 600ft ASL,030 over,trail port,20cc domes,TDR reeds,full fmf fatty's, stock carbs,K&N,full airbox with no snorkle,cover with 8x 1inch holes. At 65 deg F 27.5 pilots and 300 mains is what I gotta run. I have to work to keep the fronts on the ground. Them mains to me are way to small , you have gotta be running lean.
  6. VIN:JY43GGW01KC006155 World region:Asia Manufactured in:Japan Year:1989 Make:Yamaha Model:YFZ350 Body style:All Terrain Drive type:RWD Cylinders:2 Cylinders JY43GGW01KC006155 has not been identified as a vehicle listed in the VINCheckSM Theft Records. JY43GGW01KC006155 has not been identified as a vehicle listed in the VINCheckSM Total Loss Records. VINCheckSM is updated regularly as additional information is reported.
  7. I just bought these 2 UNI TWO STAGE POD FILTERS.They have about 1 hour of run time on them. I have been invited to run some hairscramblers and these are not going to work for me. I am looking for $25.00 shipped anywhere is the USA for both them. They where installed on stock 26mm mikuni's.All info is below. First come first serve. [email protected] for paypal (gift the money for $25.00 please). Reply with sold if you purchase them. Thanks Manufacturer Part #: UP-4182AST COLOR Black/Red FLANGE I.D. 1 3/4" LENGTH 4" (102mm) MATERIAL Foam/Urethane SEGMENT Street/ATV/Off-Road STYLE 15 deg Angled TYPE Air Filter
  8. I would first believe carb issue. When the bike starts pull the choke on. If putting on the choke allows the bike to start to idle and or the bike runs better at under 1/8 throttle then that means pilots are to small or clogged up. If you have not done a compression test on it I would suggest to do that as well, Low compression will not allow the crankcase to create enough vacume to draw enough air through the carbs. This will not allow the cylinders to get enough atomized mixture to fire. My best guess is you got issues with your pilot jets.
  9. Pull the plugs,drop some fuel down the holes,put the plugs back in. Kick it over and if it starts then it narrows it down to either carb issue's or compression issues.
  10. Picked up a complete seat from him, arrived just perfect. No suprises here. Top notch price. Thanks for the heck of a deal
  11. Look into a carb sync tool, it measures the airflow and allows you to sync them up.
  12. I have these posted over at E2S as well, Good aluminum DG nerfs that come off my 01 project shee. No cracks , with blue nets. Couple pictures of them installed and a picture of them upside down so you can see there is no damage on the underside. These are packaged and ready to ship. I am asking 50.00 plus shipping. If interested give me you zip and I can give you shipping cost. Ya i know I am new here, you can check out my rep at E2s. Thanks
  13. I was in need of some headlights,463duner got em to me super fast and great price ( 2 thunbs up mate ).
  14. Sold, money sent.
  15. Pm sent this morning m8
  16. send me pictures of the full skidplate setup and we can go from there. [email protected]
  17. I am looking for a set of stock headlights, I just cant see paying the crazy prices on ebay for them.So I was referred here from E2S. Thanks.
