Doug Austin
Everything posted by Doug Austin
  1. Sounds like the float bowls are swapped. There is a left and right bowl. In the bottom of each bowl is a small well. The left bowl has a small jet in the bottom the right does not. This supplys extra fuel when you pull the choke lever. If there backwards you have no choke.
  2. Dave Jeff has a sno-mo trailer I'm sure he would let you use. Only problem is getting it. He's at m59 and milford road. Give me a shout if I can be of any help. 248 982 0998
  3. Weather looks great!
  4. Bobs is running every Saturday this month!! Test and tune till you run out of fuel! Always a good time and a fast track.
  5. Forget the cams for your banshee. You need this!
  6. Bobs Family Raceway. Test and tune 10am-4 Make tons of runs!! $25 Come on out!
  7. Cancelled. Three inches of rain.
  8. This Saturday T&T Gates open at 9. Come on out and make a run or 2 or 40 Bobs Family Raceway
  9. Not sure on the price. What was it last time? I thought $20 but I'm probably wrong
  10. Bob in having another "Run for fun" day this Saturday the 20th A all day test and tune starting around 9 Get in TONS of passes!! Web site is down Last event for the year :sad:
  11. I wont ride a trail bike anymore without one. Had a pep on my banshee and it made a huge differance. No more sharp feedback through the handelbars. Steering feels much smoother in the trails
  12. Are your carbs from packard?
  13. The pvl does work..REALLY..lol
  14. WHAT!! What are you saying here??? People wouldnt lie would they? Hoppers is a 4 mil right? LOL
  15. if the kill leads from each coil are connected in any way it wont spark. Something about feedback. Any single switch designed for a pvl would require two leads with a diode inside to prevent this. If all else fails HERE is a link to there troubleshooting web page.
  16. If it would rain a bit I would feel better about missing this one. But nooooo perfect weather :: I'm off to a dance recital..................complete with screamng kids....and no klotz...
  17. Man I'm jealous!! Been running around all day like a madman thinking of you guys tearing it up :shoothead: It's just not right!! lol
  18. I know you said you disconnected the teather and you had one that works for a pvl. Do you have the two kill leads pigtailed together in any way? Is this a new unit?
  19. I rememeber the first time I went down a dragstrip. I was in shock! Went up and told them there clocks were wrong I know I went faster then that! Point is the first time to the track is usually a humbeling experiance
  20. LOL I see I'm not the only one who has to try and sneak in a little time here and there to wrench on the toys ::
  21. Firehead I'm curious did you figure this out?
  22. I ran a pvl for years. Never a problem with it. Simple to set up and a nice clean package. BUT I cant say I ran any faster with it. For what it cost I beleive my money could have been better spent. Dave the gremlins I was having towards the end of the year wasnt the ignition. The seaction of one dome broke inside the oring ( the small divider between it and the chamber). It leaked a little coolant and trashed the top of the cylinder $$$. Still ran 4.09 like that lol Going to go back to a stock cdi with a nology coil this year to satisfy my curiosity. Firehead when I first installed mine I didnt see any spark. After a few calls and bit of panic I checked it again with the lights off and a good hard kick and it sparked. They have a rather weak spark until the rpms come up. Grounds are very important as you have heard. I grounded the coils to the frame and then a ground from there to the side cover and one to head as well. Be sure you have the small and large spade connectors plugged in properly. The small pigtail off the coils is for the kill switch's. You have two teathers correct? I tried running one and it wouldt run
  23. What he said!! If you run with out them then you need other means of keeping the motor from moving under power. Ever feel like your chain is skipping teeth under power? Either its loose or the motor is moving. The stock mounts are fine for a trail bike but for a drag bike I think more is needed. Either a torque bar mounted on the side of the motor. I dont have one so no pics for ya . Here is a pic of what I run on my drag bike.
  24. There not the same. Far cry 2 coming later this year. I built a new computer to play the new generation of games. Crysis is simply amazing when played on a high end machine. Would be even better if they would support dual video cards like cod4 does. Another excellent game :beer:
