This is a USED ACE Fabrication Swing arm for a Yamaha Banshee. It comes with the bearings installed as well as the bushings and OEM pivot bolt. It also has the Rad Manufacturing twinrow bearing carrier with 250r style chain adjustment, as well as the brake caliper bracket that allows the use of your stock Yamaha banshee rear brake system. This is setup to use the OEM or equivalent YAMAHA BANSHEE axle. i don't the if it is extended or not, but measuring from end to end, i get 22 1/2 inches
This item was removed from a USED 2001 Yamaha Banshee. Most parts are interchangeable between all of the Yamaha banshees however, you should check on the fitments of the item with your dealer before purchasing. I can gaurantee this item was from a 2001 Yamaha Banshee 350.
$400 shipped UPS ground in the 48 states
