Merlin
Everything posted by Merlin
  1. Merlin
    WTB 9" rear rim
    Looking for a set of 9" rear rims for the banshee. Must be straight, can be oem or aftermarket. Let me know also will need to be shipped to Nova Scotia Canada. Thanks
  2. I just finished the yfz a-arm install with shock, and my shocks are also touching the upper a-arm, only barely. Also it seems as though the shocks ahve hardly any tension as I adjusted the spring about half way with only my hand spinning. Any help on this would be great. Thanks
  3. Sorry about that, 0-maybe 500ft I run in the winter and summer, so 0C t0 30C, I think that would be 32F to about 90F
  4. Hey all, The site has been exreemely helpful so far as I have made a few mods to my shee. I keep taking things apart and fixing/upgrading as I go along and my next thing is to get the jetting spot on. So as of now, I have FMF fatty's, powercore II silencers, timing +4, v-force reeds, and K&N filter with a K&N lid. I want to play with the jetting, where should I start and what should I have in the garage to tune properly, in the way of jets, needles, etc. Thanks
  5. Thanks for all the replies, I'll give it a try tonight and see what happens.
  6. I started the yfz front end transformation and I can't seem to get the ball joint separted from the spindle, both the top and bottom. Are there any tricks to doing this? I have an automotive pickle fork, but it seems to be oo big. Second, on the a-arms that I bought, the upper ball joint boot is torn a little bit. Can I replace the ball joint? WIth either a new one or the one from my old a-arms? Thanks for the help
  7. I believe that mine is much further than that, after looking at it from last night. I wold almost guess close to 1 cm. Would that be the culprit?
  8. I didn't put on a new stator?Shoudl I? As for the pickup, I really didn't check exactly where it was I just assumed it would bolt back on the plate. What should the gap be? As for the wires I checked those and they seem to be fine. Thanks for the replies Keep helping and making suggestions.
  9. Hey there all, I just installed a rm timing plate and adjusted it to +4. The bike ran like crap. (backfire, sputter etc.) So i put it back to ) degrees and it still ran like crap. I put in a new set of plugs and ran it wot from 1-4 and shut it off. The tops where a light gray, maybe even whitish which is lean. The problem is, before I installed the timing plate it was working great. I believe its either a bad timing plate, possibly my staor went while I was doing this or I may just need to rejet. If I rejet, what should I go with?? The bike has 125 psi in each cylinder, fmf fatties w powercore 2 silencers, K&N filter and K&N lid. I drive most of the time at less than 500 ft, and the temp range from 20F - 90 F. Any help wuold be great?
  10. For mods I have a K&N filter wil a K&N lid. I have fmf fatties with powercore II silencers. Thats about it. I don't understand why changing the timing would make it that diferent after it has been running great. Also, after putting it back to 0 degrees and it didn't change has me stumped. Could the pick up be too far away or too close cause that sem to be a little adjustable? Any help would be great. Should I turn the air scews in some to see if that makes it run a little richer?
  11. I put it back to +2 and it didn't run any better. So then I put it back to 0, and still no better. When I went for a ride even near wide open it was backfiring and sputtering. My pipes semed really hot as well. Anyways I then put in a new set of plugs and ran it WOT 1-4, and shut it off. I pulled the plugs and they seemed a little whitish grey on the top? Any help would be great. I was hoping this would be an easy mod and now the bikes works like s@#t. It was running so great.
  12. Before I advanced the timing I was at 125-128 in each cylinder. I'll head out and back it off 2 degrees.
  13. Hey all, I just installed a adj timing plate and set it at +4. I took it for a ride and the bottom half of the throttle sputters and backfires. Once it open up it works great. Any suggestions? BTW before I advanced the timing it worked very well, with no hesistation. Do I have to re-jet or should I just advance it 1, 2 or 3 degrees? Thanks
  14. I have the actual flywheel puller from yamaha, so it doesn't have the nut on the top it has a T handle. Do I just keep turning it until it POPS off. I don't have a flywheel holder,so what can I use to keep it from turning.
  15. I don't believe there is anything wrong with my bike. Plugs are always a nice chocolate brown, motor sounds good. I have been doing lots of reading about the 93 octane and everything kept saying do a compression test to be sure. I wanted to make sure I could advance the timing and still have pump gas. Next I would like to lok into getting a NOSS head. One other question, will I have to rejet if I advance the timing +4?
  16. I just went back out and did another compression test after letting the bike warm up. After all was said and done, I checked it 4 times on each cylinder and I kept getting betwen 125-128 psi on both cylinders. Is this bad? BTW I'm at sea level maybe 200 ft above Are you referring to the compression after I install the timing plate or just how it runs?
  17. I just did a quick compression test on my 03 shee and it was at 125-128psi in both cylinders. I did the test cold. I have 2 questions. 1. Should I warm it up and do it again? Its pissing down rain form that storm. 2. I have a rm timing plate, if I go to +4 will I still be alright with pump gas? BTW the motor is stock, with stock head and carbs. Have FMF fatties with powercore 2, k&N filter etc, but that shouldn't mater with compression Thanks
  18. Merlin
    WTB 450 a arms
    Hi all, I'm looking to buy a set of 450 a arms(modded for the banshee preferable). Also looking for a noss or pro design cool head with 21 cc domes. Thanks
  19. I have a set of razrs and I have another set of knarleys coming. I changed the gearing to a 15/40 so I don't spin as bad. I think I have apro design cool head with 21 cc domes. Would that be good for my area. Thanks again guys.
  20. I'm looking into a timing plate, just don't know which one to get. I'm looking at a cool head now. I can't get rid of the lid cause I ride in some wet areas. I have a K&N in the box and on the lid with outerwears. Port and carbs will come maybe later. Thanks again
  21. My elevation would be between 0-500 m. Less than 1000ft. So for the cool domes where is the best place to get them and where will I gain top, bottom,?? Thanks for the quick reply. and you're right it's an addiction. The wife hates it
  22. Hi all, I'm new to the forum and I have a few questions. I picked up an 03 banshee last summer and have been riding mostly trails and the odd track. I was wondering what should be the next mod to the engine. As of now I have FMF fatty's, powercore 2 silencers, K&N filter, and v force reeds. I'm in the process of getting rid of the tors setup and putting on a set of 450 sfront shocks. That is where she is now. I also want to be able to still use pump gas. Thanks in advance.
  23. Is the throttle still for sale? Can you ship to Canada?
