04fireshee
About 04fireshee
  • Birthday 12/12/1982
    horseheads, ny (upstate ny)
    well the fireshee was in a garage fire and i bought it dirt cheep. all it needed was a wire harness cdi and plastic all under 100 bucks
04fireshee's Achievements
  1. No I dont think im blowing this out of proportion. I think I would know when something is not sounding right and this is not sounding right. When that bit*h sounds like a fu*kin firecracker blowing up behind you you cant tell me thats how aftermarket pipes are suppose to sound and it only seems to come from the right pipe left pipe sounds normal like a banshee should IMO i think you should figure out wheather its backfiring or "popping" when you figure out what its doing then ask for help. im sorry do be an a$$ but you have got every one around here confused on what its doing. everybody has tried to help and tell you something diffrent, you may have made the problem worse if your messing around with stuff that you dont know what it dose, if its just a popping sound then dont worry about it. if its a backfire then tell us its a backfire we can steer you in the right direction.
  2. i cant speak for everyone but most all stock banshees are geared real high it takes alot to get them rollin' so your 1/4 throttle is fine. i use 32:1 mix with amsoil interceptor and i never have a problem
  3. prtty much everybody else nailed it on the head. the only other thing that no other person said is to make sure to put the pistons in facing the right direction. the arrow facing the exhaust port. and take your time breaking it in. jeromey
  4. to tell you all the truth, i think your blowing this out of proportion. i have an 04 banshee and have had many other banshees. if yout piped generaly the head pipe is thinner and has less curves to quiet the sound a.k.a. your wonder pipes(stockers). all of my shees that i have had pipes on them have "poped". what your hearing is the cylinders firing the pipe has less curves so it just makes it louder. thats all... nothing to worry about but if you have made any changes to your air screws id advise you to check your plugs to make sure you havent leaned your baby out. jeromey
