Arizonaduner
Everything posted by Arizonaduner
  1. I just ditched my stock carbs in favor of some 35mm PWK's. What should I do with the harness connectors (For the carbs?) I'm not ready to fire it up yet but will it even run with the stock connectors disconnected? Thanks, Steve
  2. I'm ready to put my Cub cyl's on my new motor and I'm unsure about using RTV on the base gasket. I bought these Cub cyl's used and had them replated. I noticed RTV residue on the bottom of the cyl's when I first received them. I didn't think you wanted to put RTV on cyl gaskets. Please advise... Steve
  3. See attached picture. I was shooting for +6
  4. They look good. I'll PM you for details. Steve
  5. Looking for a set of stock Banshee rims - Silver. Let me know what you got. Thanks, Steve
  6. Thanks Brandon. I had pretty much given up on those 3 parts being in the engine. But I'll keep a close eye out for them elsewhere. The moral of the story is - Never just "Toss" other unrelated parts in with others without leaving some kind of note. Steve
  7. Well actually it's not a missing puzzle piece, it's an extra puzzle piece. The spring and two washers/spacers (See attached picture) were in the bag with the Shift drum (I could have tossed them in from another sub-assembly by mistake?) and I cannot figure out where they go. I have looked thru both the factory manual and clymer manual and cannot find what they are and where they go. I don't want to go any further on the engine build-up until I figure this out. Any ideas? Thanks, Steve
  8. Looking for stock Banshee silver wheels/tires. Better than 70% tread. Let me know what you got. Thanks, Steve
  9. 19cc Noss/Pro-Design domes for a stock cylinder. Never used. $45 + shipping (For the pair). Steve
  10. I have a set of un-used 19cc Pro-Design/Noss domes (For stock cyls) and need to trade for some BB (68mm) domes. Looking for 19cc or 20cc. Thanks, Steve
  11. Just bought some used Cub cyl's from Bansheecub and they arrived as-described. Good transaction. It took apx. 2 weeks to clear customs and ship from NB to AZ which is about normal from what I understand. Steve
  12. I want em' I'll PM you for details. Steve
  13. I'm interested if you still got em. I'll PM you.
  14. I just bought a used Banshee and the owner said he had Wiseco pistons put in. I disassembled the top-end and I need some help in identifying what pistons I have. 513's, 795's, or something else? The only numbers/symbols I can make out are 393L(?) and an eye symbol on the underside. Piston diameter is 66.4mm and pin center to piston top (Not including dome) is 35.8mm. Pin bore diameter is 16mm. Any help would be appreciated. Thanks, Steve Tucson, AZ
  15. I've wondered about keyed crankshafts before (Vs welding) and I just ran across one at Vito's performance. It would seem to me that going with a keyway would be a better way to go but they are outnumbered 20:1 compared to welded cranks. http://www.vitosperformance.com/atv_parts/...=200&page=1 Anybody have experience with these? Any thoughts? Steve Tucson, AZ
  16. I need some advice. I need a new crank and I'd like to get a +4mm. I'd also like to keep my stock cyls (Already ported) for now. By using a stroker plate, and two base gaskets, it looks like the port timing will stay close to the same (I feel comfortable altering it a little if needed). My question is, what sort of sealing issues or problems have been encountered with the stroker plates? My alternative, if I don't use the stroker plate, would be large changes to the port timing in the stock cyls which I'd like to avoid if possible. This is what I'm considering: http://www.vitosperformance.com/atv_parts/...=200&page=1 Thanks, Steve Tucson, AZ
  17. Eric, I live in Sahuarita and work at the Komatsu Proving Grounds. I want to catch up with you pretty soon. I'm gonna move on some PWK 35's but I don't know if I should go with the Airstrykers or not. I'll PM you and talk some more about it. Steve
  18. My rear sprocket is toast. When I replace it, I think my choices are 39-43 tooth (It's got a 41T). I would like to keep my stock front sprocket (It and chain are almost new) and most of my riding will be at Glamis. Very soon I will have some PWK 35's, ported cyls, and Vforce 3's. I plan on keeping a stock crank (Welded, but not stroked). I ride pretty aggressive, but just play riding. What gearing (Rear sprocket) would you guys recommend? I've never ridden my Banshee at Glamis yet, I just got it. Should I go with steel or aluminum? Thanks, Steve Tucson AZ 96 Banshee
  19. Brian, I've followed the progress of Mullet man's a-arm project for a while but I just saw that you're now offering "Ready to go" kits. Great job and it sounds like you're getting good feedback from you're customers. I was curious if you have any feedback from guys running non-Yamaha OEM shocks like the TRX450 and LTZ400s? Thanks and keep up the good work. Steve Tucson AZ 96 Banshee
  20. Thanks. Very good info! Lots of good advice. I'll post a pic when I'm done with it.
  21. Thanks for the advice!
  22. Any type of staple that's better than another?
  23. I just bought a seat cover and will be installing it this weekend. Any tips on what works/doesn't work? Steve
  24. I'm looking for a stock swingarm skidplate. Let me know if you've got one FS. Thanks, Steve [email protected]
