streetbanshee
About streetbanshee
  • Birthday 09/21/1990
Contact Methods
    california
streetbanshee's Achievements
  1. would u be willing to sell me the axle alone
  2. right now i have a 4 mill stock cilinder setup with a dune port and polish i have 35 kiehins on it and was wondering if i go to the 2into 1 mod with a 35 if it will affect the performance too much
  3. i got a pd coolhead studs and 22 cc domes for 140 torch lights both for 55 durablue front and rear lowering kit both for 75 and i got an asv f3 clutch lever with the on the fly adjuster no hotstart for 80 ill try and get pics up in these next couple days
  4. For the head set them at 20 lbs and the clinders nuts i always set them the same as the head
  5. cool thanks guys
  6. yea i checked that kit from dennis kirk looks good i was also looking at the new needle valve assembly from the yamaha website but who knows how much it costs
  7. They are the stock carbs just wanted to know if i could get them somewher other than the dealership i already cleaned em and adjusted the float height i think its the seats any help would be apreciated
  8. Do you still have the cilinders ? If so how much are you looking to get for them im just interested in the cilinders and pistons
  9. I'm interested in running the same setup what was the total for the crank,pistons,port job and cutting the domes
  10. pretty much got everything except tires carb is a pwk 33 or 35 dunno forks,swingarm,shock,linkage,frame,intake boot,gas tank,plastic,stock reeds with carbon fiber reeds hole whole engine except the crank all the internal gears all the clutch components the cases where cracked by a rock pretty big whole so i just threw them away pretty much anything you need
  11. how much would u want for it ?
  12. Sure that would be great
  13. i atleast need the carbs cables and intake for the trade
  14. found out it was the header was leaking so i took it off and tightened it down evenly and the problem went away thanks alot for the help though
  15. You just have the airbox off do u have pods or 2 into 1 filter for pods like a 250 around ther
