bodge
Everything posted by bodge
  1. hi just sent you a msg on ebay
  2. if a motor has been bored 2mm will this make a big difference?
  3. http://www.trailtech.net/ the vapor fitted mine last night and for 70 uk
  4. Thats where i have just fitted mine that came with the trailtech vapor. So we are both correct or both wrong , lol i think head to rad... the pump flows cooled coolant through the engine up and out of the head to the rad. ????
  5. that would be the bottom hose then? but i have been told it flows from the head to the rad at the top then out the bottom to the water pump through the engine and so on. ???
  6. Hi wot pipe is best to put a temp senser in ? the one from the head or the one from the pump? I take it one will show engine temp and the other the temp after it has been cooled.
  7. if i lower my shee will it still be ok to go on trails. and what is the best kit to get for the front and rear and how much should i drop her? over in the uk i use it alot on the roads but also go on some mudy trails.
  8. done that and there is no spark. i did hit it hard but only with a hose pipe and not a power wash.
  9. hi just washed my shee, i covered the air intake with tape to stop water from going in the air box. whent to start it but forgot to remove the tape, any way it would not run , removed the tape but still will not start. what is the best way to check for a spark? Or how do i test what is coming out of the stator?
  10. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...bayphotohosting
  11. how do you start your she from cold and warm it up before you ride it? should i be using the throttel to start it or just the choke?
  12. Thats what im asking, will i gain anything? If not then i will sell it. Thanks for your help.
  13. the thing that worry's me is will it change my ign timing to much with it being set at +4 and do some damage? come on guys must be some tech's out there.
  14. I have one of these sat doing nothing, should i fit it or sell it or bin it? My shee has got a the timing set at +4. pipes v3 reeds carbs jetted http://cgi.ebay.com/ebaymotors/ws/eBayISAP...Y_BIN_Stores_IT
  15. put one wire to ground and the other to the black/white wire from the cdi unit. Thats how mine is fitted.
  16. have you a pic of your she from the front? looks cool by the way.
  17. that's what i thought but so many people on here do it.
  18. i have done my back wheels and was going to do the fronts but the front will end up wider than the back end. is this ok?
  19. would it be ok in my shee? http://cgi.ebay.co.uk/grasstrack-speedway-...1QQcmdZViewItem
  20. there must be a stock seting for the timing even if the cdi varies it.
  21. can not find the write up. any help ?
  22. will the cdi still varie the timing when its set at +4 then? il do a search for the write up.
  23. what is a stock banshee timing set at?
  24. is that a no to the cdi/rev box then?
  25. up to now my mods are dmc alien pipes carbs rejeted ricky stator set at +4 i have just got some v-force 3 reeds to fit and also i have a magnum at-0409 aggressive curve cdi/rev box. can i fit the new rev box with my timing set at +4?
