r2n2d
Everything posted by r2n2d
  1. How much for the frame shipped to 02649 MA. thanks Rob
  2. My shee is running better on choke. I am getting better throttle response. Does it mean my pilot is to small or what. Is my main to big?
  3. My brother is looking for some used pipes just to by. let me know if you would sell out right and how much to ship you MA if you can.
  4. I am interested in the frame. I cracked mine up the other day. let me know the price and where you are. thanks
  5. r2n2d
    Rolling banshee!
    I am looking for a banshee close to or in MA. I live in Cape Cod. I have a motor so I was looking for a roller. I have plastics and other parts but let me know if anyone has one.
  6. ttt
  7. I am looking for the trail tech stock mounts for the lights. I already have the lights and handlebar mount but, I want to move them from the handlebars to the stock location. If anyone has them for a decent price or want the handlebar mounts then let me know. I also have pics available. Thanks Robert
  8. Do you have any pics? I am interested where do you live
  9. I was testing my stator to see if it was my problem with my spark. I know on a stock stator it should be between 13.7 and 20.5. I have a 200w ricky and wanted to know if 27.4 was in the specs for a 200w
  10. I hadn't touched the clutch or anything. I had the tors electrical unplugged. I have keihn 28 pwks so there was no need for them.
  11. My bike has been acting weird lately. When I start her up she idles fine. Once I put it in 1st and let the clutch out it stalls out. I can rev it with the clutch pulled in but I am not sure whats going on. Any ideas????
  12. If you still have the roller could you let me know the year, pics [email protected] and price? also where in ny, I am in MA thanks Robert you can just send all the info to [email protected] thanks again
  13. whats your asking price?
  14. I ran the bike today with the needle on the 2nd the clip 160 main 42 pilot. It was strong in the mid but it seemed alittle slower on the top. When I move the clips down to the 3 or 4 will it effect the top alittle? I have to do it for the hestiation anyways. but just thought I would ask before then. Also did the plug test. It was a light gray brownish color.
  15. So before i switched the jets I started it and it didn't start first kick it was like a few. I then switched to the 160 main and the 42 pilot needle 2nd clip(2nd from the top). It started with both chokes on on the second kick but it began reving higher than it should at idle with the chokes on and backfired. I turned the choke off and it shout off. it still was hesitant when I start on the gas. what should I do?
  16. I am running 50:1 amsoil Dominator
  17. I had installed the carbs on my shee with the main 135 and the pilot at 38. It started first kick and stayed idling. It was bogging out when I hit the throttle. like it was trying to catch up to its self. After like four sec the mid kicked in very strong and the top was better. Do i change the pilot even thought it started right up and idled or do I change it to the 42, which I am still waiting to be delivered? Also should I run a 155 main instead or the 160?
  18. I am selling some of my spare shit. I will also have a stock steering stem and a set of stock 03 carbs with tors removed 280 main 27.5pilot. Everything in the pic has to go. make a deal or price.
  19. I am selling some of my spare shit. I will also have a stock steering stem and a set of stock 03 carbs with tors removed 280 main 27.5pilot. Everything in the pic has to go. make a deal or price.
  20. thanks I think i'll go with the 160. I am still waiting for the carbs so i'll keep you's posted on what size worked the best.
  21. what size pilot? and is the lrd needle alot better than the keihin one? I think they may be the same 148 on 4th clip and 160 on 2nd. because the needle is stitting lower in the 160 where as yours is on the 4th clip making it sit higher. I think! but then again I am here looking for a spot to start thanks for you input.
  22. I'll start there thanks for your help. also would you recommend a dial jet for those carbs and if so where would I get them? so I can dial in faster than rejetting everytime. just a thought.
  23. the guy that sold them to me told me they have, "The jets are 135 main jet, 38 slow jet, 3.5 throttle valve, and JJH needle"
  24. I currently have fmf sst pipes, coolhead 22 or 21 domes, k&n filter in airbox with lid. no snorkel. I ride near sea level. (0-maybe 500 ft) Cape Cod, MA temp ranges from 40-90 degrees I had jetted my bike with the stockers at 280 main, 27.5 pilot. needle in the middle what would be a good starting point for me, with the keihin 28mm PWK's?
  25. I have the trail tech endurance. It works great. like MyQquad said it has more than just speed as a function. It is worth the 70 bucks check ebay they always have them. Also give trail tech a call they had very good customer service when ever I called. www.trailtech.net
