quadlt500
Everything posted by quadlt500
  1. i had the same trouble and i just got mine back from the shop today and it was the little black box for the tors. they unhooked it and it runs now. i went thru everything and the yfixed it by unhooking that
  2. it has fmf pipes and jetting. it sat for 2 years cause he had one cylinder go dead and then i got it and had it bored and that is as far as i got
  3. im back with banshee troubles. ok i tried my cdi and coil on another banshee it ran fine i put them back on mine and it sparks about 1 time between 8 to 10 kicks. i need to know if anyone has any ideas. and also what safty swithes can i unhook, and witch ones cant i unhook. i was told to unhook the tors but i also heard u had to hook up the 2 yellow wires to each other. can anyone help me on any of this?
  4. i tested the stator and coil the red and green ohm 17.4 white green and white red ohm 112.8 my coil ohm at .9 the book says .25 to .38 i belive. so u think it might be my coil?
  5. i tested white with green lead and the white with red lead. and they tested right the coil i tested it and the reading was .9 the book call for .25 to.38 i think. so i am guessing my coil is bad.
  6. ya i got that one also
  7. ya i unhooked the black box unhooked the wires from carb unhooked the parking brake wire is that all and do i need to connect any wires together
  8. i unhooked the tors. the black box the wires on the carbs and the parking brake wire is that all i have to unhook. do i have to hook any wires together. i tried testing my stator. i got juice thru one wire it was the yellow wire and thats it. is that the only one that is suppose to have fire?its a 97 banshee
  9. i tried testing my stator. i got juice thru one wire it was the yellow wire and thats it. is that the only one that is suppose to have fire?its a 97 banshee
  10. i tried testing my stator. i got juice thru one wire it was the yellow wire and thats it. is that the only one that is suppose to have fire?its a 97 banshee
  11. i have 130 psi
  12. the carbs are right i marked them when i took them off. the not reving isnt whats bothering me its the no spark problem. the tube is in there
  13. get her a yfz 450 or a warrior my wife loves both
  14. get her a yfz 450 or a warrior my wife loves both
  15. it just got bored yesterday. it had 50 psi before that
  16. it will start up and idle but will not pull itself u have to hold the throtttle in some to keep it running and if u open it up all the way it wont rev anymore its revs to a high idle thats it
  17. the 450 will take it from the get go and the end. i know i have both and i have raced both. i have fmf pipes but my 450 will smoke the shee even if u go with a rolling start. both are the best quads on the market as far as i am concerened
  18. if its like the lt 500 where u can install reeds out of a kx250 then it really does work but i havnt tried the blaster ones
  19. i have a 97 banshee i just bought. i had it bored. it wont start. if u pull start it it will start but wont rev up when u shut it off it it will fire once and that is it it wont fire again any ideas. i tried another coil and it wouldnt fire either any help would be appreciated
