SAMUNOWAY
Everything posted by SAMUNOWAY
  1. Where are you located?
  2. I currently have the PWK33 single carb, pipes, and +4 timing and my jetting is at 168 main, 40 pilot and DEK needle on 3rd clip. I just got my cylinders back from Eric Gorr for his woods port, I am upgrading to the PWK35 and have added V-Force reeds. Does anybody have similar mods that can give me a good starting point? Thanks.
  3. I have the Denton stabilizer which I believe is basically the same thing and am very happy with it. It really helps save your arms through the rocky stuff.
  4. I use Motul 800 @ 40:1
  5. Are you using a fuel filter?
  6. My bike has been sitting with a full tank of gas for about 4 months. Should I run it or drain it and refill it? How long does gas keep after its been mixed?
  7. Where is it leaking from?
  8. Sometimes when I shift the bike will go into neutral even when I'm shifting into 4th. It happens alot into second but now 4th? Anybody else ever had this problem?
  9. If you ride tight trails +2 arms can be a problem
  10. boll*x!!! ?
  11. Motul 800 @ 40:1
  12. SAMUNOWAY
    Air Box
    I am looking for an air box, filter, and the adapter for the single carb set-up.
  13. I need a coil with wires. Do you have one? If so how much shipped to 90638? Thanks
  14. I'm running the CV33 with 168 main, 40 pilot and DEK needle in the 3rd clip. Runs great. Only mods I have are pipes, open k&n and +4 timing.
  15. What is the compression suppose to be at? I've got 135 on one side and 132 on the other. I'm at sea level. I can't find any specs in my Clymers.
  16. HOW MUCH FOR THE V-FORCE?
  17. I would like to know how much also Boonman. My flywheel is from Ricky Stator and they claim it has bigger or stroger magnets for better lighting. Does that matter?
  18. I am looking for an air box & air box adapter for the CV single carb set-up.
  19. I AM RUNNING 168 MAIN, 40 PILOT, AND NEEDLE @ 3rd CLIP. CLAMP ON K & N FILTER, +4 TIMING AND OLD SCHOOL FMF PIPES. OTHERWISE STOCK MOTOR.
  20. ME NEITHER
  21. THANKS SREDISH.
  22. DOES ANYBODY KNOW HOW HIGH COMPRESSION YOU CAN GO AND STILL USE THE SHIT THEY CALL PREMIUM IN CALIFORNIA. 91 OCTANE.
  23. I AM NEW TO THE BANSHEE WORLD. I HAVE WATCHED THIS WEBSITE FOR A WHILE AND ALOT OF YOU SEEM TO KNOW YOUR SHIT. MAYBE YOU CAN HELP ME OUT WITH. I HAVE PEP FRONT SHOCKS WITH RESERVOIRS. THERE IS A VALVE ON THE BOTTOM OF THE RESERVOIR. WHAT IS IT FOR? AM I SUPPOSE TO DO SOME KIND OF REGULAR SERVICE ON THEM?
  24. will they work with j-arms?
