woodman
Everything posted by woodman
  1. You look cool now
  2. Your right. Your a much smarter person than me what was I thinking Im sorry. This was all made up anyway. This is why we allways see the banshee in the gncc right. And dirtwheels calls you assholes when they need advice on banshee mods and aftermarket parts. You people are what makes forums great. A waste of time coming to this forum. Blue duece what is it a torch or mig make up your mind. You dont know what that is right. Just from what youve seen on tv Im sure.
  3. Quote this
  4. I cut about 4 on each side and its great.
  5. Look in Tips & Tricks
  6. Yes its easier
  7. What he said
  8. He is right the bottom a arm has to modified. The half inch cut off the outside t mounts has to be welded on the inside or washers added.
  9. You can turn your front wheels around.Gives you two and half inches on each side. Requires you to bust the bead and drill a hole on the opposite side of wheel. Must plug the old hole with a plug or put a valve stem in backwards. You can turn your back wheels around to give a half inch on each side.
