Daniel Gottschalk
    4mm cub by K&T
Daniel Gottschalk's Achievements
  1. Ya id like to try em as well. Idk if my 4mill cub would pull em or not. Whats the rollout and tire size
  2. I've ran CPI and shearer. Liked the shearer better
  3. I think it's a good idea. Been a member since 03 then got out for a while. Just didn't post much. It'd be a while before I'd get 50 posts I just felt like it was pointless to post if It was already answered or the post wasn't helping anyone
  4. I've rode with one on a ktm dirt bike and they are amazing. Self adjusting. If I wmet back to a Mx bike instead of a drag bike I would get one fornsure
  5. I have used heli coil on everything thtat has stripped in thenpast on my bikes. Just be careful. Hi speed drill without pressing very hard so it don't catch. Then use cutting oil when you tap it backing the tap off frequently to clean then threads out. I've never had problems doing it. Good luck!
  6. I also ran pro circuits on my non ported motor. Loved them. I now have shearer on my cub. Like them a lot more than my CPI. Rev out higher. If u plan on porting ur bike I would go out and go get them. If not I like pc or t5s
  7. I'd check ur float level. Mine stuck open and filled my entire motor up with alcohol. Seemed like it blew 2 gallons out the exhaust once I finally got it started.
  8. Toomey has some decent stiffer springs. Do you already have a lockout? I run 3 stock 3 stiff springs with mine. If you are wanting to put more weight to them put a longer bolt and 2 nuts on them. Make sure the clear ur cover first. I've had the same clutch for 3 years in my bike and K&T said it looked good yet when I rebuilt it this winter. I don't have any weight added on my lockout either
  9. If you ride in a lot of water and mud I doubt you will like them. Just gonna suck moisture and water in your motor. Other than that pods help quiet a bit
  10. What you looking to spend? Most people have more money in their stock cylinders than you could pick up a cub top end for.
  11. Looking for a drag axle jj a or lodestar also would like some drag a arms pm me or txt me 7856233029
  12. i have a 350 cub motor i want to sell. It only has prolly 20 hours from when it was new. motor was put together by jeff at F.A.S.T. it has a stock transmission comes complete a coolhead. modquad lockout and cover. and stator and flywheel. I need to have 1700 plus shipping out of it. call or text me at 785-623-3029 i can take some pictures and send them if you are interested
  13. well the weather friday night sucked but i had a blast thurday and friday.. i am horrible with names so dont really remember anyone... i know i was parked right across from spurdy and them.. the all black banshee if you seen it ran it is the one that needs a longer swingarm!! lol but all and all i had a good time racin'
