banshee320
Contact Methods
  • Website URL
    http://
  • ICQ
    tescott, ks
    2000 banshee, blue, cool head, 20 cc domes, 4 degree timing key, fatty pipes, shift star mod,
banshee320's Achievements
  1. Do you still Elka Dual Rate shock and swing arm? You can email me at [email protected]
  2. I have a banshee and it has bad reeds. I dont believe they are stock reeds. There are no reed stoppers but they appear to be stock cages. I have always had v force reeds and never dealt with stock cages. My question is do some aftermarket reeds install in stock cages not useing reed stoppers. I am not sure if I have stock cages or not.
  3. I have a set of cylinders that are ported. The exhaust height from the deck to the top of the port is 27.5 and transfer ports are 42.5mm to the deck. Can someone tell me if this is a low, mid, or top end port. I know this is not the whole story and no one could say for sure but I just wanted a idea on what to expect from these cylinders.
  4. I have a set of ported set of cylinders that are 100 over. does anyone know what it cost to resleeve them.
  5. Do you still have cylinders. Very interested. Do they need bored and if not do they come with pistons. Mike Adams. 785 283 4775
  6. Can someone tell me which oils have a aditive that make clutchs slip.
  7. I have some banshee parts to put on ebay. Can Someone give Me a idea what I will get out of these parts. 1Comeplete front brakes not including rotors. 2 comeplete rear brakes minus brake hub. 3 stock a arms. 4 hot rod crank needs bearings.5 Air box with pro flow and k-n filter.Front hubs and rotors.
  8. I have low mid port,v force 2 reeds,cool head with 20cc domes ,+4 timing Knarley pipes pro flow with foam filter. My question is if I went with a single 35 carb would I loose much top end. I have never had a single carb but with Knarley pipes top end is limited and iI thought it would be good for my set up.I ride mostley tight trails. Any feed back is wanted.
  9. Parts for sale Complete front and rear brake systems. All 4 a arms stock Extended lonestar axle used Air box with proflow adapter and k&n filter Front Shocks 2 works front shocks for 400ex 1 with broken rod triple rate
  10. I have a set of works shocks on my sons 400ex. They are triple rate with no rezies. He hit a tree and broke the shaft on the shock. Anyone know what it cost to rebuild both shocks. I think it probably better to get new shocks but it never hurts to ask.They are about 5 years old and seem to work okay but i am sure they were needing service anyway.
  11. Looking to get new pipes. I have fattys and really like Knarleys. Seen some LRD's for sale. Do the Lrd's have good bottom end. How do they compare to Knarleys.
  12. I purchased another banshee and was told it has a lonestar swing arm with round house carrier. I would like know if it takes stock axel bearings and swing arm pivot bearings. If it does not, does anyone know what kind of bearings it takes.
  13. Asking for starting point with low mid port. 030 milled head +4 timing .050 weisco no lid on air box stock carb 1200 elevation
  14. Wanted some pictures if possible. Mike Adams. email address is: [email protected]
  15. I have located a dyna port pipe but is does not have a silencer. Is there another silencer that will work with this pipe or where could I get a new one.
