01bansheefox
Everything posted by 01bansheefox
  1. I have a TCS Rear spring & everything you need to convert your stock spring to this, The fronts are TCS Zero Preload setup for 180lb rider so im guessing the rear should be the same, Remember this is just the rear spring and other little componets its not the whole shock. I really really need a set of front tires and rims size 20'' on chrome rims.
  2. Ya sorry got it backwards for some reason I thought smaller number=smaller part. Typo.
  3. Well i always try to be a bit on the safe side so i think i do about 42:1 but would it make a difference if I cut down to like 35:1?-37:1?
  4. Can I lean out my fuel to even it out? It seems my banshee is just 1 step high to rich nothing worth rejetting over but if I do a differnt oil ratio will it help it a bit more?
  5. Pretty cool video on mowers......... http://videos.streetfire.net/search/tracto...D4DE74CCE5A.htm
  6. Nice bargan get it while you can......... http://sacramento.craigslist.org/spo/151001318.html
  7. Is Wicked the brand name or something maybe im not seeing it...... You didnt list a name or a picture...........
  8. So you havnt done that stuff yet??? Why not just save that money you were to put into the shee and put into a truck? Isnt that smarter?
  9. Our weather is really weird this month its still about 55-60deg's and raining in Nor Cali. Usually about 70deg this month so fishing is behind.
  10. I have an old cb 650 engine and the head needs a new gasket it leaks oil where the head connects to the cylinders now.... can I just put some of that gasket goop stuff that makes a gasket and seals it or should I spend the $70 for 1 gasket. How can 1 peice cost $70 also? Ive looked everywhere.
  11. Well i mainly do small lakes & ponds... I have a boat but its a Jet Boat dont think I can do much fishing off of that lol anyway I will go to the fish & game store I have in my area.
  12. Really got the urge to do some fishing past couple of weeks but it has been raining and alot of the water here is still cold and high, Is there anything I can fish for? Im located in N. California
  13. http://cgi.ebay.com/ebaymotors/Lifted-Ford...1QQcmdZViewItem
  14. But remember I switched the plug wires around to see if it was that and the left cylinder still fires perfect.
  15. Well if I had two I would sell two but I pulled it off a dirtbike. And alot of people do the 2 into 1 setup and a 36mm is a good size for that.
  16. Its just 1 carb... comes with hoses and no cable. $85 shipped.
  17. Well i dont use the chokes in fact I cant because the carbs are so big i cant push my lever up or down both of them always stay down which I think is off, i have never touched them before.
  18. Well yeah bigger is always better to a point...........
  19. Mine starts up fine but its only the left cylinder running the right side doesnt even make a noise and another thing after about 5min of running if I pull the plug out there is no oil on it and its not even warm.
  20. Ya im thining it might be a carb problem too but if it was the intake boot would that make it not fire?
  21. Ok where to start...... Bike ran 100% perfect one day, came back week or 2 later and only the left cylinder runs and the right will go on and off every few seconds, If you run it for 10min the pipe will still be cold and the other pretty hot. Also if you take off the left smokes normal and the right will blow nothing then all of a sudden blow out smoke like a mother then shut off again. 1. I switched both plug wires, still does the same thing 2. Put new plugs in and gets good spark 3. Has compression I did notice my right intake boot has a crack in it, but I cant tell if its big enough to suck in air but would that make fire on and off? Thanks
  22. Ya but the price will still be $250.... Buy one, get one free
  23. I didnt know LSR frames were made for 4cylinder engines. I wanted something that is made so I can drop in my engine.
  24. First to PM me, i will ship out tonight. Size 36 Lectrons not set up for alchole NO cables or filters just the carbs with hoses, great condition.
  25. Well i was just stating my opinion, I like it alot.
