Craig Walker
Everything posted by Craig Walker
  1. I have an all aluminum frame i believe plus 2 in the front with radiator extra hardware and a set of unmatched engine cases. I've polished it out needs a touch up job and a couple of joints re welded by a pro. previous guy got no pentatration. If you are interested email me At [email protected] I'm not shipping it you have to come and get it in colorado.
  2. Dont really know the frame is a plus 2 in front
  3. http://westslope.craigslist.org/rvs/2564595921.html I'm asking 10k but will trade for a 06 or newer jet ski, if you have any question call me 970 456 2534 i have more photos and can take more.
  4. well after today results that is what i'm going with becuase i don't have freaking clue what is going on now. I removed paint, replaced bearings and got it to go about a 1/16 to the right about 7/8 more to go, then i got pissed and ground the sprocket hub to make it go more to the right, and gained 3/16 more to the right 1/2 to go. last ditch effort took shims out of front on the swinger and got an 1/16, i have 7/16 to an n where to make up for it. God i hate LSR shit. fuck it i'm going riding weither chain stays on or not.
  5. I mean right not left
  6. What did you find out what was knocking you off aligment? I'm having the exact same issue with a LSR swinger and carrier. Some of my findings are, I have powder coat on meeting edges guesuing about 1/16 worth of paint, worn out bearings and upon inspection there is an spacer tube that will prevent both sets of bearing to completely seat estimating holding each side out a 1/16 on each side. into the carrier so when the new bearing come in there are going to get smaked all the way to the left. Hoping i'll get 3/16 to the left with all fixies and then if that dosn't work i'm grinding the inside edge of the chain hub to get even more left
  7. Oh WTF I put a simple question on this radiatior. I can't beleive the amount of hipocritical crap on here about buying a radiator from over sea's, Didn't your banshee come from over sea's lets think, Why yes it did it came from over seas. I"ve purchased one myself and not very happy with it, it was dropped shifting the frame of it. still useable the metal is not very thick but it does polish nicely It did save me over $200 in cash sorry if you want to charge that much money my money goes to the lowest bidder.
  8. This is so much fun to cause hate and discontent, I'm not out to get buisness on this site, I just think it is funny that people only claim to do "HIgh End Work" All there photos are billet aluminum, I have respect for a person that has tried some of the Nasty shit oxidized, pittied, horrible casting streaks, and inside duals on over the road truck. But hey, as all of us polishers do we brag about our stuff and mock the others, but in the end it all oxidizes and the makes a yet another round to the next polisher.
  9. Billet is way easy. And i sand too I stop at 220 grit and finish up with my wheels.
  10. I havn't got a clue to keep steel for long periods. tried zoop seal? or when done for the weekend coating it in a grease to stop the oxidation, maybe vasoline. or a bottle of favorite hand lotion lol.
  11. you called my bluff she freak, not many people venture off to try other metals especially ferus metals. your chrome molly looks good. I about pulled my hair out doing a stainless steel bull barrel on a $8k gun.
  12. the axle threads are 14mm 1.5 pitch for anyone that wants to know cost me $80 to figure out for a set on amazon, now that its out there you can get the die only for about $20-40. ill will be making a post on the front near future.
  13. that is real helpful thnx
  14. ok what is the thread siize for the nuts that hold on the rear hubs
  15. looks good guys done any stainless steel, or chrome molly or anyother ferus metals? something other than billet aluminum?
  16. Ya i still do. http://s806.photobucket.com/home/walkerlol/index
  17. Your powder coat question is expensive I had my motor cases and all done with a steering stem and rear axle 600$ Now I think i got hosed on the deal but that is a different story. Polishing out your motor (jugs, and clutch cover) cheetah cub generally will run more but should run about 175-250 bucks. then if you want the cases polished add another 150 easily. I'm giving the prices that i used to charge havn't compared my prices to anybody lately but it could be less.
  18. ok did some more rotations and found 20deg of timing advance is .80, 15deg is .40 10deg is .20, 5deg is .10.
  19. This is built pretty good now there have been cracks that had to be redone but the builder whomever it was ground the welds smooth so that is why they cracked.
  20. I'm trying to set my timing to 10 deg before TDC on a 4mill 421cub. Now correct me if i'm wrong by checking on a degree wheel I rotated it 10deg to find about .20 give or take on the dial indicator. Is this number usual for you guys that are running a PVL on a 4mill. Reason why i'm asking is that it seems that the piston is to low to be firing the sparkplug. That and the last motor that I ran a PVL on it was about .10 on a stock length crank. I know whinning over .10.
  21. anyone have an idea i've continued on with this bike having the steering stem lengthened several inches over factory thinking +8. the radiator i lowered inside the frame praying that i'll have enough room for pipes. now i'm running into a new unexpected issue Hardware, when the frame was made the aluminum brackets are 2 time thicker than factory and now i can't find anything chrome or stainless main killer is the upper a arm bolts, and the swing arm bolt. http://s806.photobucket.com/home/walkerlol/index
  22. I've used Semichrome, and now experimiting with PEEK. I do all my polishing on edge cutting wheels using emery,tripoli, and white rouges I've havn't seen any differences between the two when i do touch up stuff but it seems that the peek will clean up any extra rouges that i don't get off. I've han't found any good use for mothers, and some of the local napa store stuff. Heres one couple of things to go by that seem to work, don't buy stuff that smells like gasoline because they use white rouges and gasoline to make the mix. If it stinks like amonia it is diffently worth trying as long as it takes your breath away. here is something else to help if it really bad, sand it. get it up to 1000+ grit that will remove almost nasty oxidized areas and most any polish will work after that.
  23. I'm getting my she setup with the same motor 4mil stock port cases matched (vito I've been told), now the carb and clutch setup i'm little confused i'm been hearing mixed reviews that the stock clutch that it will hold??? The plan is to get a straight cut main drive and hinson basket do i need to get the 8plate??? Then the carb size I have now is 36mm good bad or do i need to find a set of 35mm planning on running 110octane, until i get bored with gas and start running liqour through it.
