rogerrabbit1971
About rogerrabbit1971
  • Birthday 06/06/1971
Contact Methods
  • Website URL
    http://
  • ICQ
rogerrabbit1971's Achievements
  1. I am in Anamosa, IA. Close to Cedar Rapids
  2. I forgot to add to the list that it has an LoneStar axle locknut, RPM millinmum carrier, RPM sprocket carrier.
  3. Looking to get some cash. Got another little one coming the end of October. If that wasn't the case, I would probably take you up on that offer
  4. MX Race Ported Motor Fresh motor from bottom to top end, approx. 8 hrs on motor Matched Cases Bores .030 over Custom made Dyno-Port 2n1 Pipe Pro-Design Cool Head Boysen Rad Valves 28 PWk Kehein Carbs - Taper bored to 29.5 Nology Coil Braking Brake rotors all around LoneStar +2"+1" A-Arms Hinson Clutch Basket Hinson Quick Change Clutch Side Cover Laeger Roundhousing -2" swingarm RPM Dominator +2" Axle Custom Axis Dual Rate shocks Riken front tires on HD wheels Turf Tamer rear tires on beadlock wheels Duncan Steering Stabilizer Duncan Front Bumper AC Pro-Peg nerf bars Pro-Design Tether switch Shift Star Mod Pro-Design Pro-Flow Plate S.S Brake Lines Extra Stuff Included: Complete gasket kit, Throttle cable, Jets from 130-170, Pilots from 35-52, Quad Stand, 5 K n N Filters,Shock outerwears, filter outerwears, AC Front Bumper Located in Anamosa IA, Near Cedar Rapids Email [email protected] for pictures or further information (Couldn't upload the pics)
  5. Make sure that you leave the center lug. I made a set that looks like a x-mas tree. You can repeat the pattern about every 4 or 5th row. Look at a sled studding pattern and that will give you some ideas
  6. Go with Axis. Can't go wrong there. Had mine for 10 yrs now
  7. Use 28pwk, the throttle response will be a lot better and crisper. You will like them more than the 34-35. Plus you can taper bore them up a 30
  8. Krause Racing has the best and lastest longing chain & sprokets. They also make the chain for sled also
  9. Paint might be causing the problem. Look into a Nology Coil, it puts out twice as many volts than the stocker. You check the spark and you will see a flame instead
  10. I will try to get some pics up this weekend. Location is Anamosa, Iowa. Extra tires(and orignal ones too), clutch & throttle cables, pilots and jets(a lot of them), extra front and rear sprokets.
  11. 1993 Yamaha Banshee Screamin' Performance Machine ~ MX Ready *Original owner *Fresh motor, completely overhauled from bottom to top, only 5 hours on motor *Dynoport 2-into-1 exhaust *Custom Axis dual rate front shocks (compression adjust) & single rate rear (compression & rebound adjust) *Lonestar +2+1 A-arms *Leager -1 Round housing swingarm *Dominator +2 Racing Axle *8" rear beadlocks w/Turf Tamers *10" HD front aluminum wheels w/Riken tires *Pro-Design Cool Head *Boyeseen Rad Valves *28 PWK Keihins tapered bored to 29 1/2 carbs *Hinson Clutch Basket & Hinson Quick Change Clutch Cover * Invested over 10K, a steal at $2800 Many extra parts, contact for more detailed list [email protected]
