Bensshee
Everything posted by Bensshee
  1. I don't think that they will be that strict this weekend. Hey proline are you bringing that fast red and black one this weekend? I'll have to see you on the drag strip.
  2. yeah I will have to try the choke trick. It is hard to keep the shee quite. According to the weather channel it is suppose to be 45 to 50 degrees.
  3. If you don't have a spark arrestor the DNR will not let you in. There is no riding double. If you girlfriend doesn't have a bike just bring the truck out on the dunes and switch on and off with the shee.
  4. I have a set of bear claws on ten inch rims. They are like spider tracks but are lighter. They hook up awesome. I am selling the tire and rims for $100 if interested.
  5. Only a week away. I hope it is in the 50's or 60's next weekend , hopefully the warm weather will hold out.
  6. you have mail
  7. I am looking for a good working rear brake caliper for my 95 shee. I don't need the brake lines or any of the parking brake components.
  8. Try a air impact wrench, that is what I use.
  9. Bensshee
    Air Box
    I have one with a lid. Right now there is a prodesign foam filter in it. Make me an offer.
  10. 10w-30 will work
  11. you have mail
  12. Somebody earlier posted how to polish the clutch cover but I can't seem to find it using the search engine. Can somebody tell me the best way to polish the clutch cover.
  13. My compression is 155 what octane gas should I run?
  14. you have mail
  15. I'll be there, it is only a couple of weeks away.
  16. That I don't know. Noss is on this website do a search and ask him. I have heard nothing but good things about the noss head.
  17. Bensshee
    Uni Filter
    I used to run a prodesign foam filter in the airbox with no lid for years at the dunes and never had any problems with sand getting sucked in the motor. Just clean the filter between trips and make sure to put the foam filter lube back on.
  18. Big bore domes go in a regular pro design cool head.
  19. Silver Lake opens April 1st. I always go the first weekend it is open. There might be a little snow here or there but it still is a good time.
  20. Check your sprockets maybe the teeth are wore out, eliminate the easy stuff first.
  21. I'll be there as usual. Should be a little cold but always a good time.
  22. Is there any benefits in buying a high output stator other than running bigger lights? I need a new stator and trying to decide between a ricky stator stock replecement and a ricky stator high output.
  23. Thanks Benbb I will try that. I looked in my clymers and they never showed any distinction between the years. I will let you know how it works out.
  24. I need to know how I can swap a 96 cdi with a 95 cdi? The 96 has one more wire than my 95 does, do I need the extra wire? I have the tors disconnected. What does the fifth wire go to.
  25. I am going up to cadillac this weekend with some buddies. I am going to start going to race on lake St. Clair; the boat ramp closest to palms road. I live close to port huron maybe I will try out there, where are you guys at excactly? I will try 16 and 18 front sprocket will these fit with my chain saver on?
