SHEE_17
Everything posted by SHEE_17
  1. if you banshee can do 125 ill kiss your butt
  2. I have tripple rates with rezzies adn i have nothing bad to say about them there a smooth shock for some one who wants a non expensive shock to perform like the "elka" shock i rell cant tell a diffrence between them ive rode the with the best and with out and they perform just like the elkas in my opinion
  3. UNI all the way
  4. take a pipe wrech and tighten your axle bolts all shees prolly do that one time or a other
  5. Are your front rims bent ?.,........check them.......if you cant find out the problem just put sand bags in the tires and see if that helps or i would check the bushings and grease
  6. at the back of the banshee there is a blue wire that sometimes comes disconected and it causes them not to work ......i just had to fix mine and they work just fine now so just check the wires in the back and see it there all conected
  7. go to walmart ad get some grey wheel paint it is the same thing and same color i use it about once a month to keep the shee lookin good
  8. i had the same problem a few month ago and i took it to the shop to see if they could find out what it was and come to find out one of my transmittion gears broke of and was grinding the othger gears of also but i had to replace my whole transmission but i found a used one for 200 so it wasent so bad but lets just hope your problen aint that serious
