ELMER Posted March 22, 2005 Report Posted March 22, 2005 HEY MY SHEE STARTED BLOWING OIL OUT THE BREETHER HOSE...NOT SURE WHY...ANY HELP? THANKS Quote
spoin39 Posted March 22, 2005 Report Posted March 22, 2005 Do you mean the coolant overflow hose? If so, you got it real hot! Quote
racer Posted March 22, 2005 Report Posted March 22, 2005 NO THE CASE BREETHER HOSE.... 342985[/snapback] you must have got that thing real damn full. Quote
FIRST BANSHEE Posted March 23, 2005 Report Posted March 23, 2005 you must have got that thing real damn full. 343301[/snapback] I agree, if it's over full it will blow out. Quote
AUSSIE BANSHEE Posted March 23, 2005 Report Posted March 23, 2005 YOUR GEARBOX MIGHT BE BUILDING UP PRESSURE FROM THE CRANKCASE, HOW OLD IS THE ENGINE? Quote
fixitrod Posted March 23, 2005 Report Posted March 23, 2005 Yeah, I found out if you run to much it does the same thing. Quote
racer Posted March 23, 2005 Report Posted March 23, 2005 maybe next time you should get oil saver gears. Quote
MotulMonsta Posted March 23, 2005 Report Posted March 23, 2005 Funny think about blowing oil out your breather hose is that once it starts, you'll never really get it to stop. My shee's been doin it for years now. I've rebuilt the motor, lapped the case mating surfaces, re-routed the vent lines and it still does it. I'm not venting crank pressure. I'm not worried about it anymore. Just check the oil before I ride and in between motos and call it good. But if you are venting crank pressure, a shure sign is oil fouled plugs..especially if it sits for a while. Also where the water pump is, there is a breather hose port. That port sits below the oil level and so the oil if your riding real hard will find it's way through. I tried plugging that hole, but it didn't work for long. I got a few more tricks to try out when I pull my motor apart again. Quote
