what are all of the things you have to do to maintain a banshee like ive siade b4 ive had three 2-strokes and i know you clean the airfilter, check the plug and that bout all i know a far as maintance is.
so what are all the steps i need to take b4 and after ridin P.S. i ride a lot!
the biggest difference you will prolly notice, expecially being in atlaska is jetting for the temp changes. dont run her in the winter when its set for 70 degrees.
i got it off someone from AK so the carbs might be jetted already??
you said it has pipes and k&n right? if it does it has been rejetted at some point. someone correct me if i'm wrong but i believe you rejet for ever 25 degree higher or lower and i'm not sure the elevation changes.
no stock pipes now
  • 7 months later...
Geeze Alaska. Hows the weather there? Anyway I usually just do a little routine of what you already said. After about 1 good day of riding I usually change the clutch oil which I use 10w 30 Royal Purple or Castrol GTX. Other then that just check your bolts after every ride or if you been riding all day which I don't know if you do beings its way to cold lol well for me it is anyways I check my bolts after every 3 hours. Just to make sure. Can't afford to loose anything.
