I have an 02 Banshee with 350 in frame cpiracing pipes, Vforce 2 reeds, stock carbs, k&n filter, boost bottle, +4 timing.i'm in washington state at about 400 to 500 ft. elevation.need advice on where to set jets and needle size, etc. Please help!!
Is it a K&N pod or is the K&N in a an air box? If it is in an air box, are you running a lid? This will make a huge difference when jetting. Post this info up and someone should be able to help you.
I have both pod and in box filters. right now i am running an in box. the lid is on but there are three one inch holes drilled in it. lid came that way.
