fastashell Posted August 9, 2008 Report Posted August 9, 2008 hi everyone, well i bought the -2 swingarm. the guy said there was no chain guide hookup because it was to short to fit one? anyways im installing it but ran into some problems. first the prm skid plate i have was to long so i cut it. now the length is good but when i attach it the sprocket hits so i removed the little strip of plastic but now the sprocket and disc just barley touch the sid plate. just a tiny bit but i know it needs to be addressed. anybody else run into this problem? any easy fix? any skid plates out there that have longer tabs than the prm? Quote
ClimbAnyHill Posted August 9, 2008 Report Posted August 9, 2008 I would modify those skid mount tabs to lower that skid! Quote
fastashell Posted August 9, 2008 Author Report Posted August 9, 2008 how do i do that, the swinger is chrome and i dont want to mess the chrome finish Quote
peterlocal22 Posted August 9, 2008 Report Posted August 9, 2008 might be easier to bring it to a fab shob and add a couple inches to the skid plate tabs? Quote
ny98banshee350 Posted August 9, 2008 Report Posted August 9, 2008 (edited) i kno ace hardware by me sells chrome spacers for motorcycles and shit any where from 1/2" to and inch try a local hardware store or motorcycle shop? Edited August 9, 2008 by ny98banshee350 Quote
fastashell Posted August 9, 2008 Author Report Posted August 9, 2008 i kno ace hardware by me sells chrome spacers for motorcycles and shitany where from 1/2" to and inch try a local hardware store or motorcycle shop? im not having a problem w spacers. its the length of the tabs i guess are to short. the bottom part of the rotor and sprocket are rubbing the skid plate. maybe i will try a custom skid plate at a fab place? i though that this may have been a common problem but i guess not. wasnt sure if maybe some skidplates have longer tabs? Quote
peterlocal22 Posted August 10, 2008 Report Posted August 10, 2008 if your sprocket and rotor are stock size and wont spin because there bottoming out on the skid plate i would say the swingarm tabs are too short as long as the skid plate is new and has not been tampered with Quote
bronco91shee Posted August 11, 2008 Report Posted August 11, 2008 why not just ditch the skid plate? its just extra weight anyways? Quote
peterlocal22 Posted August 11, 2008 Report Posted August 11, 2008 (edited) oh waite a second, if its a roundhouse then you need to make sure that the axle, when rotated, is closer to the top of swing arm. This set the correct ride height and chain angle. It also raises the axle so hopefully it will bring it up high enough to be above the skid plate. let me know how it works out Edited August 11, 2008 by peterlocal22 Quote
