HARTZ55 Posted August 6, 2008 Report Posted August 6, 2008 hi, i have t-5 pipes,and i live at sea level (Cape Cod), last fall the bike ran fine,but when winter came around ,it wouldnt kick over ,so it sat until spring,and it started up fine. Could anybody be able to help me out ,with what my jetting should be? Please, Thank You Quote
LiftdT4R Posted August 6, 2008 Report Posted August 6, 2008 Are you running a full air box? Lid and all? Irf you are then you should be around 260 mains 27.5 pilots Air screws 1 turn out Needles on middle clip It should run a little rich in the winter and your going to have to use the choke to start it, but you shouldnt really have to rejet in the winter unless its really really cold, like below 0. Quote
J-Madd Posted August 6, 2008 Report Posted August 6, 2008 Stock pilots are generally fine with T5s, but it will run with 27.5s. What kind of air filter, and what timing are you running? Quote
HARTZ55 Posted August 6, 2008 Author Report Posted August 6, 2008 thank you, yeah my choke is broken, i pull it out and it pops back in...idk what my timing is?? i have a toomey air box, with the cover, and a new moose filter Quote
