Pincushion Posted August 4, 2008 Report Posted August 4, 2008 I just picked up a 03' with an estimated 20 hours. I believe the guy as the frame and everything looks great, but I'd like to get a compression reading for the helluvit. My 06 YZ250 pulled a 215lb reading after a fresh top end, which is great compression for a 250 and shows my gauge is in the ballpark. With that in mind what should I expect from each cylinder? Stock motor, stock carbs, FMF fatty's and K&N's (no airbox) are the only mods. I'm at 300ft ASL. Lastly, should the reading be taken on a motor at operating temp or stone cold? My YZ blew a 215 at operating temp and lower when cold. Quote
mdhc500 Posted August 4, 2008 Report Posted August 4, 2008 (edited) I just picked up a 03' with an estimated 20 hours. I believe the guy as the frame and everything looks great, but I'd like to get a compression reading for the helluvit. My 06 YZ250 pulled a 215lb reading after a fresh top end, which is great compression for a 250 and shows my gauge is in the ballpark. With that in mind what should I expect from each cylinder? Stock motor, stock carbs, FMF fatty's and K&N's (no airbox) are the only mods. I'm at 300ft ASL. Lastly, should the reading be taken on a motor at operating temp or stone cold? My YZ blew a 215 at operating temp and lower when cold. #'s from NOSS Machine... .........Sea Level..1000'.2000'.3000'..4000'..5000' 18cc.........197.....178...171...170.....165.....145 19cc.........183.....167...160...158.....152.....137 20cc.........169.....156...149...146.....140.....129 21cc.........156.....145...138...134.....128.....121 stock........130.....125...118...112.....106.....100 I would say between 120 and 130 psi give or take and look for them to be betwwen 1-3 psi difference per side. Check it cold, with WOT and kick it until you get the highest #... Good luck Edited August 4, 2008 by mdhc500 Quote
Pincushion Posted August 4, 2008 Author Report Posted August 4, 2008 Good info. Thanks a bunch! Quote
Pincushion Posted August 6, 2008 Author Report Posted August 6, 2008 (edited) It blew a 125 and 120 respectively. I was able to repeat those numbers twice. Is a 5# fluctuation something to be concerned about? I took it out yesterday and it runs and sounds great. I hadn't ridden a Banshee since the mid 90's and I forgot how much fun they are. Good times.... Edited August 6, 2008 by Pincushion Quote
