sandunagen Posted August 4, 2008 Report Posted August 4, 2008 when I started riding last night, my headlights starting going on and off. if i rev real high they would come on soon as i let off throttle the lights would cut out. checked all electrical connections. none were loose. any ideas what this would be? Quote
Snopczynski Posted August 4, 2008 Report Posted August 4, 2008 Where they as bright as usual when they were on? Quote
sandunagen Posted August 4, 2008 Author Report Posted August 4, 2008 Where they as bright as usual when they were on? yes then they would stay on for a bit, then i had to high rev it again then they would flash on Quote
sandunagen Posted August 4, 2008 Author Report Posted August 4, 2008 yes then they would stay on for a bit, then i had to high rev it again then they would flash on i swapped voltage regulator with a buddies and still same prob. it was new stator 2 years ago. it happened a few rides ago but went away real quick. Quote
Snopczynski Posted August 4, 2008 Report Posted August 4, 2008 Sounds like a bad connection somewhere. Does it always stay on with the engine revved up? Or does it ever blink off or flicker with the rpm up? Quote
sandunagen Posted August 4, 2008 Author Report Posted August 4, 2008 Sounds like a bad connection somewhere. Does it always stay on with the engine revved up? Or does it ever blink off or flicker with the rpm up? even in high rpm still flashes on off just not as much. sometimes in iddle it stays on till i kick in to gear then goes out. Quote
Snopczynski Posted August 4, 2008 Report Posted August 4, 2008 Do you have a digital multi meter with an ohm checking function? Quote
sandunagen Posted August 4, 2008 Author Report Posted August 4, 2008 Do you have a digital multi meter with an ohm checking function? i will borrow one tomorrow. what should i check? i appreciate your help. need to get this fixed we are going on a trip in 2 weeks Quote
Snopczynski Posted August 4, 2008 Report Posted August 4, 2008 i will borrow one tomorrow. what should i check? i appreciate your help. need to get this fixed we are going on a trip in 2 weeks Check from your headlight ground to the motor for resistance. Check from the headlight positive wire to the stator yellow, and then the voltage regulator lead for resistance. You gotta check with thew switch on. Was it doing it on high and low beam settings? Does the tailight blink or go out also? Quote
sandunagen Posted August 4, 2008 Author Report Posted August 4, 2008 Check from your headlight ground to the motor for resistance. Check from the headlight positive wire to the stator yellow, and then the voltage regulator lead for resistance. You gotta check with thew switch on. Was it doing it on high and low beam settings? Does the tailight blink or go out also? was doin it in high and low beam. i do not have my tail light connected. Quote
Snopczynski Posted August 4, 2008 Report Posted August 4, 2008 was doin it in high and low beam. i do not have my tail light connected. what did you do with the tailight power wire? Quote
Delos Posted August 4, 2008 Report Posted August 4, 2008 ahh...electrical problems...could be long or could be short...i don't know the schematics of the banshee...but the first thing i would check is the on off switch...jump it and see what happens..could be why its flickering...if that don't work do what the guy said above about the meter thing..this could be long once you get into that... Quote
sandunagen Posted August 11, 2008 Author Report Posted August 11, 2008 i hooked my tail light back up. still same problem. Quote
Snopczynski Posted August 11, 2008 Report Posted August 11, 2008 Go to walmart and get one of these. Check back here and I will tell you what to do. They cost less than $30.00 Quote
mercury65 Posted August 11, 2008 Report Posted August 11, 2008 i had a simaler prob. the person that had the bike before me moved the wires to the top of the motor just under th gas tank and they melted on the exaust and were shorting out on the exaust. also check for chafing were they tie them to the frame. Quote
