how many bottles of engine ice does it take to fill a dry banshee engine?
Just a tad under 1/2 gallon.
They come in 1/2 gallon jugs
If you drained it completely, whic you should if you were using other coolants in there, it will take 1/2 gallon, like .45 gallons. I had some left over
Hey man, no problem.
You never know when you may need that other one, or maybe put it in your other bike. It works for sure. Well worth it. These things get hot pretty quick if you get on them.
I have 1 or 2 extras sitting in the garage on the bench for whenever I may need it. I saw more coolant leaks in my time out in the coal hills than I can care to mention. If you don't have an extra when you get home, what are you going to use, you know? That's why having that extra 1 might be a good idea.
You will like that stuff though if you never used it before.
