I was wondering if anyone is familiar with an ohm meter? I just got one to test my stator and coil and the stator checked out fine (was between the range that the Clymers stated was acceptable) but the coil is showing all zeros on the same resistance setting that the others showed correctly with. I think that this means my coil is bad. I was hoping someone had some prior experience that would share, so i dont go purchasing a coil that i dont need.
Does anyone know where to get a coil for a good price?
thanks for any help.
In the clymers on page 237 it has a table of ohm readings for the electrical system. It says that the primary should have a reading between .28 and .38. The secondary should have a reading between 4700 and 7100. I have only tested the primary and got a reading of 0.00. Anyone tested their coil before and familiar with this.
Please guys this is a new build which i have not been able to get started and i am getting frustrated with this.
thanks
