my banshee is back firing and shooting flames out the exhaust how do i fix this. i just put in new pistons but im pretty sure its a timing problem im not sure. i need to know how to adjust the timing what the marks look like. someone help me i am confused and my parents are mad
ive been looking around and lots of sites said it could be running lean. i start it up and it idles like crazy backfires flames everywhere i havent messed with the timing but i did install new wiseco racing pistons. lots of sites say to adjust the airscrew but i dont know which one is the air screw. there is a big fat screw on the outsides of the carbs and a little one facing up on the insides. i would like to know which one is the airscrew if either of them are.
Both of those screws are the airscrews. But if the bike is running lean those screws really wont do shit to help it. What are all the mods done to the bike? Then you need to figure out what jets are in the carbeurator. Also how does the bike run.
i have fmf fattys with power core silencers, cool head with 18cc domes wiseco m series racing pistons boost bottle, the carbs are stock.
it ran fine before i put the new pistons in
not sure what size the jets are, or even how to tell i ahve 2 sets one for winter and one for summer
do you think i need to go bigger with the jets or what
as for running when i start it it idles really really high sounds like its going to explode then it backfires and shoots flames.
Edited by █╚98banshee╚█
Also what about the choke crossover tube?
i had the carbs off but not apart im pretty sure there on right
for flames to be coming out of the exhaust doesnt that have to be a timing issue or am i wrong.
i have the black fuel line where it comes to a T all hooked up right and the clear orange tubes are just over flow and breathers right. thats all of the tubes right?
i need how to adjust timing. is the stator magnet thing where the timing is. i dont get.
i had it running perfect before the pistons but i pulled the stator off to clean it up.
these are my two questions
is the stator(magnet spinning thing) affecting the timing?
do i need to rejet just because i put in new pisstons?
alright you got me snopczynski what the hell does the choke crossover tube look like is it black
i can see where it goes
fixed the problem with the back firing but it still bogs down when i go full throttle. i give it gas and the left silencer blows a lot of white smoke and the right one blows no smoke and it bogs. what might the problem be? i have both sets of the air screws set the same could it just be a bad plug or what?
you said your running 18cc domes... You may want to check your compression..You may need better octane fuel and have a detonation issue. 18cc domes on pump gas can get ugly
