I mounted up the Tirnity Exhaust system (thanks Austin!), and everything went relatively smooth. The silencer hangers, however, are giving me a bit of grief. Can you folks confirm that the bolt size for the hangers is 8mm with a 1.25 pitch? I had to source longer bolts (the Trinity hanger requires a 60mm bolt), but although the pitch looks and feels identical to the old bolts, I can't seem to get the new bolts to thread in smoothly.
TIA!!
Are you positive the new bolts are metric?
You could very well have a standard 5/16-20 bolt.
The thread specs are very,very close between the two and you wouldn't be able
to tell the difference between them, without pitch mic's or thread gauges :geek:
